0 Front Master Cylinder Gaskets & DOT 5
Last Post: 1Scooter
0 Finally a Dyno session to my 90 c.i.
0 Worth fixing?
Last Post: Triple Disc
0 XL Bomber - Portuguese project
Last Post: Akeemking
0 first electrical problem
Last Post: tonelop
0 New guy
0 Pinion gear position
Last Post: NP72Iron
0 changed exhaust, now popping codes and running bad.
Last Post: Andy56
0 Sportsterpedia Progress
0 ironhead oil pump pressure
Last Post: jeffro57
0 Sissy bar and rack for 883
Last Post: RandallM
0 So who's UK based?
Last Post: Dusz
0 Upgrade carb kit
Last Post: ericfreeman
0 Mid or forward controls.
Last Post: lostNdallas
0 He... He... He...
Last Post: ZTatZAU
0 oil cooler
Last Post: MDT
0 Burly Stilletto 13" shocks or ?
0 Chinese sportster
7 Hello from Baltimore, MD
0 What do you want for Christmas? - 2022.
Last Post: Keep it running
0 Arthritis
0 93 sportster switching to laced wheels
Greg81XLH (57), saylor01 (56), Alicia (54), latnyte (53), antonini (45)
chopper, custom build, rigid evo, rigid frame
Old 19th June 2021
ThenCameHarry ThenCameHarry is offline
Sportster/Buell Model: XLS
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1999
Other Motorcycle Model: 2 Ironheads XLH
Other Motorcycle Year: 1979
ThenCameHarry has disabled reputation
Default Recommended rigid frame brand?
My plan is to build a rigid frame chopper using my 1999 Evo sportster motor.
Probably with
35 deg rake, 2” stretch and 1” rise …… well ….. maybe …. 🤔
I’ll probably end up buying a frame through Dennis Kirk, Sportyparts or JP Cycles.
Of the different brands/manufacturers I would love to find out which frames have been proven to be the most reliable.
Some brands that come to mind:
Paughco, Kraft Tech, Drag, GMA, V- Twin
Thanks for any help from those of you that have build choppers.
Cheers,
Harry
Old 22nd June 2021
LocoLocal's Avatar
LocoLocal LocoLocal is offline
LocoLocal is an unknown quantity at this point
Paughco and Kraft Tech are well thought of. Led Sled is another that comes to mind as being used by a lot of reputable builders.
Old 22nd June 2021
Thanks for your reply. Much appreciated.
Could you tell me which frame manufacturer you ended up using for your chopper build?
Thanks again.
Harry
Old 22nd June 2021
LocoLocal's Avatar
Never done a complete frame but I’ve used hardtails from Led Sled and Voodoo Vintage. The folks at Led Sled were great to work with. I don’t believe Voodoo makes complete frames.
Old 22nd June 2021
Good feedback. Thanks. I checked out LedSled on the Internet. I will definitely give them a call.
Meanwhile I got kind of interested in the “Swedish” style frames sold by Paughco.
To me they look similar to the 60’s frames used by Cliff Vaughs and Ben Hardy for the Captain America and Billy bikes for Easy Rider.
Anyway thanks again for your feedback.
Much appreciated.
Cheers.
Harry
Old 22nd June 2021
LocoLocal's Avatar
I know a lot of folks who have used Paughco and have been happy. Might want to check out chopcult which is entirely chopper focused (hard to tell by the name, right?).
Old 22nd June 2021
Akdawg Akdawg is offline
Sportster/Buell Model: PanAmerica
Sportster/Buell Year: 2021
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1985
Other Motorcycle Model: Triumph, BSA,more Sportys
Akdawg has a brilliant futureAkdawg has a brilliant futureAkdawg has a brilliant futureAkdawg has a brilliant futureAkdawg has a brilliant futureAkdawg has a brilliant futureAkdawg has a brilliant futureAkdawg has a brilliant futureAkdawg has a brilliant futureAkdawg has a brilliant futureAkdawg has a brilliant future
I've bought n sold frames at swap meets, big $$ savings
Support your local ABATE
The number of kicks required to start a sporty are in direct relationship to the number of people watching.
Old 22nd June 2021
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Swap meets most definitely can save you some $. Beware of bent frames and titling issues though.
On a side note as well, I just recently contacted Paughco with the VIN from a frame that was known to never had been registered, but I had no MSO. I provided them with some pics and a notarized statement (provided by them), plus a small fee. I was then sent a valid MSO in my name for registration purposes. Total time was about 30 days.
I wouldn’t suggest telling the seller of a frame with no paperwork about this service, just use the “no paperwork “ dillema in your favor when haggling on the price.
