Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > HARLEY PAN AMERICA FORUM > PAN AMERICA Motorcycle General Discussion and Problems
0 Mikuni HSR42 will not idle
0 Can't clear unread messages
Last Post: xLoneRiderx
0 WTF Happened
0 Chinese S&S carbs
Last Post: bordens
0 Can you ID this bike?
0 Upgrade proof, evidence backed, High Flow Air Filter/intake for EFI 883/1200
Last Post: d10221
0 My '05 1200C (insert clever title here)
0 83 XLH w/Velorex 562
0 Woke, cancel culture...
0 0Salt Flat Sporton
4 Rear Lighting WIRING help
Last Post: jsaintmartin
Last Post: koolbreeze
Last Post: ZCarFan
0 10 things i DON'T miss about my sporties
Last Post: Bigshankhank
0 Luggage rails?
0 Shady shifter shaft
0 1979 oil lines and vents
0 Newbie from Redding, California
Last Post: bklyngeezer
0 Want to rejet my 1989 883
Last Post: gary59
41caninek1 (80), InkyDoggy (70), shepsvettes (68), outlw (49), outlaw05 (49), bklyngeezer (48), Skinn (47), theguy35 (42), IronHound (42), 2013iron883 (40), huge_midgit (34)
Old 3 Days Ago
Default Pan American Owners Manual and accessory info
Pan American Accessories catalog-
https://reveal.harley-davidson.com/take-the-ride
Click on Download
What long reach spark plugs it has!
New semi syn 15w-50 motor oil.
Looks like it takes 4 quarts for a change.
New line of helmets jackets etc,
2021 HARLEY-DAVIDSON® OWNER'S MANUAL: PAN AMERICA MODELS
Didn't see a parts list yet
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
Old 3 Days Ago
Blacky Blacky is offline
Sportster/Buell Model: Hugger 883
Sportster/Buell Year: 96
Blacky is an unknown quantity at this point
I am IMPRESSED with that bike!!!!
Old 3 Days Ago
harley506d's Avatar
Sportster/Buell Model: 1200c
I'd have one in a heart beat if i could afford it.
Those plugs! Jeez!
A main stand at long last!
And,.................another oil for us to discuss!
Old 2 Days Ago
harley506d's Avatar
This from the Brit M.C.N.
https://www.motorcyclenews.com/news/...n-pan-america/
Old 2 Days Ago
Tim The Grim's Avatar
MetalWorkingXLFan
Sportster/Buell Model #2: KHK
Sportster/Buell Year #2: 1954
Other Motorcycle Year: 97
Another look...
https://advrider.com/harley-davidson...-mocos-future/
Old 2 Days Ago
Even with the 6 speed, it looks like 70 mph is about 4200 rpms in sixth (about 2500 rpms below peak torque)
Code:
| gear | gear ratio |
|    1 | 13.11      |
|    2 | 9.687      |
|    3 | 7.509      |
|    4 | 6.057      |
|    5 | 5.08       |
|    6 | 4.436      |
Code:
|   GEAR CHANGE    | MPH  | KM/H |
| First to second  |  15  |   25 | 2600 rpm -> 1950
| Second to third  |  25  |   40 | 3250 rpm -> 2500
| Third to fourth  |  35  |   55 | 3500 rpm -> 2850
| Fourth to fifth  |  45  |   70 | 3650 rpm -> 3075
| Fifth to sixth   |  55  |   85 | 3750 rpm -> 3275
Speed in MPH
Code:
|  RPM  | 1st  | 2nd  | 3rd  |  4th  |  5th  |  6th  |
|  1000 | 5.7  | 7.7  | 9.9  | 12.3  | 14.7  | 16.8  |
|  1200 | 6.8  | 9.2  | 11.9 | 14.7  | 17.6  | 20.1  |
|  1500 | 8.5  | 11.5 | 14.9 | 18.4  | 22.0  | 25.2  |
|  1750 | 9.9  | 13.4 | 17.3 | 21.5  | 25.6  | 29.4  |
|  2000 | 11.4 | 15.4 | 19.8 | 24.6  | 29.3  | 33.6  |
|  2250 | 12.8 | 17.3 | 22.3 | 27.6  | 33.0  | 37.8  |
|  2500 | 14.2 | 19.2 | 24.8 | 30.7  | 36.6  | 41.9  |
|  2750 | 15.6 | 21.1 | 27.3 | 33.8  | 40.3  | 46.1  |
|  3000 | 17.0 | 23.0 | 29.7 | 36.9  | 44.0  | 50.3  |
|  3250 | 18.5 | 25.0 | 32.2 | 39.9  | 47.6  | 54.5  |
|  3500 | 19.9 | 26.9 | 34.7 | 43.0  | 51.3  | 58.7  |
|  4000 | 22.7 | 30.7 | 39.6 | 49.2  | 58.6  | 67.1  |
|  4500 | 25.5 | 34.6 | 44.6 | 55.3  | 65.9  | 75.5  |
|  5000 | 28.4 | 38.4 | 49.6 | 61.4  | 73.3  | 83.9  |
|  5500 | 31.2 | 42.3 | 54.5 | 67.6  | 80.6  | 92.3  |
|  6000 | 34.1 | 46.1 | 59.5 | 73.7  | 87.9  | 100.7 |
|  6500 | 36.9 | 49.9 | 64.4 | 79.9  | 95.2  | 109.1 |
|  7000 | 39.7 | 53.8 | 69.4 | 86.0  | 102.6 | 117.4 |
|  7500 | 42.6 | 57.6 | 74.3 | 92.2  | 109.9 | 125.8 |
|  8000 | 45.4 | 61.5 | 79.3 | 98.3  | 117.2 | 134.2 |
|  8500 | 48.3 | 65.3 | 84.2 | 104.4 | 124.5 | 142.6 |
|  9000 | 51.1 | 69.1 | 89.2 | 110.6 | 131.9 | 151.0 |
|  9500 | 53.9 | 73.0 | 94.2 | 116.7 | 139.2 | 159.4 |
| 10000 | 56.8 | 76.8 | 99.1 | 122.9 | 146.5 | 167.8 |
To allow your engine to wear-in its critical parts, we recommend that you observe the riding rules provided below for the first 805 km (500 mi).
During the first 80 km (50 mi) of riding, keep the engine speed below 5000 rpm in any gear.
Up to 805 km (500 mi), vary the engine speed and avoid operating at any steady engine speed for long periods. Engine speed up to 7000 rpm in any gear is permissible.
Old 2 Days Ago
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: XL
Other Motorcycle Model: FXDC
That is one kinghell plug
Steve
'03 1250 stage two thunderstorm heads, 536, mik 42
'01 Cyclone
'13 FXDC 96" stock
Old 2 Days Ago
rejeanprimeau's Avatar
How much for that butt plug and what aftermarket is available???
Old 2 Days Ago
$9.95 for a pair.
Screaming Eagle plugs $28.95 a pair.
Aftermarket, not sure but it looks like the SE plgs are a multi ground electrode,
If they are 12mm and 1.04" (26.5 mm reach) these NGKs might fit
in the correct heat range-
$5.61 each at sparkplugs.com
https://www.sparkplugs.com/ngk-5214-...und-spark-plug
Similar plug in platinum - $9.27 each-
https://www.sparkplugs.com/ngk-4471-...und-spark-plug
Old 1 Day Ago
Crusty Crusty is offline
Sportster/Buell Year: 2016
Sportster/Buell Year #2: 1978
Other Motorcycle Model: XL 1200 R
Cycle World had a very interesting review:
https://www.cycleworld.com/story/bik...50-first-look/
I like the suspension that squats when the bike slows to a stop. I'm a short, fat guy and I sold my Buell Ulysses because it was too tall. I wonder how it feels to ride one? I guess I'll just have to wait until Demo Rides become available.
It definitely has piqued my interest.
