0 Searching for a used Ironhead, my observations
Last Post: Akdawg
0 03 xlh 88"
Last Post: MatHormell
0 Vintage Stinger Ignition
Last Post: stratoblaster
0 Roky's impulse buy 2001 Kawasaki Concours
0 Keith Black Conversion
0 Relocated Turn Signals
Last Post: priell3
0 09 Buell XB12 crank
Last Post: Boudwood
0 Question of the month?!
Last Post: c1skout
Last Post: Caustic Dick
0 Question on a transfer valve
0 Help with my clutch please
Last Post: DirtyHarry68
0 tried something new in my primary
Last Post: Lone Rider
0 Keith Black 10:1
Last Post: 1HD4CJM1X4K
0 My 1978 Ironhead
Last Post: VXDspud
Last Post: Sportycus
0 Hi from the UK
Last Post: VXDspud
0 Gravydog crashed again.
0 Oil Level: Hot vs Cold
Last Post: stavenironhead
0 Rubbermount Poll
0 Front brake shorting?
Last Post: Hughieboy
  #31
sportsterdoc's Avatar
Glad you are solved.
IXL2Relax (and Hippysmack) has a ton of more info in Sporsterpedia, but post 1 of this thread has some basics.
http://xlforum.net/forums/showthread...1784651&page=3
Voltage can tell you a lot.
I'm glad you got it running ----- but I'm curious...
Originally Posted by Back_Woods_1200 View Post
Now I have no headlight, tail light, turn signals or 4 ways. I do have a horn though.....lol. If I turn the key to accessory, my speedo will light up but as soon as I turn it to run (aka start), the light goes out. I did check the fuses on the block and they were all good to go. Battery tested good.
What did you do to TEST THE BATTERY that you thought it was good???
I suppose I should have recommended checking the battery anyway...
Here's the Sportsterpedia section on checking the battery cables, voltages and grounds:
Please report your SPECIFIC METER READINGS from those tests...
2 Relax
Back_Woods_1200's Avatar
Back_Woods_1200 Back_Woods_1200 is offline
Back_Woods_1200 is a glorious beacon of lightBack_Woods_1200 is a glorious beacon of lightBack_Woods_1200 is a glorious beacon of lightBack_Woods_1200 is a glorious beacon of lightBack_Woods_1200 is a glorious beacon of lightBack_Woods_1200 is a glorious beacon of lightBack_Woods_1200 is a glorious beacon of lightBack_Woods_1200 is a glorious beacon of lightBack_Woods_1200 is a glorious beacon of lightBack_Woods_1200 is a glorious beacon of lightBack_Woods_1200 is a glorious beacon of light
2 Relax
I used positive probe from meter to positive battery and the same with ground. I know now that was wrong but then what should I have done?
The idea of war is not to die for your country but to make your enemy die for theirs.
I think the key-on voltage reads in post 7 were so very low, it did not make sense, other than a very poor ground or pinched wire, etc.
Looking back, the battery probably had more than one bad cell. The other 4 (or less?) greatly overcharged, but faded instantly with load.
Anything is possible. I'm just glad to have it running again. Now maybe I can get some sleep not having it in my head as to what it might be!
ChinCactus's Avatar
I had a battery do that to me once. Started fine, parked it and an hour later, no start. Had strong lights until I hit the start button, then everything went out.
I got my trailer and picked it up. By the time I got back to it, it was dark out. Of course the trailer lights that worked when I put it away, didn't work.
Turned the lights on the bike minus the headlight and used a bungie to hold the brake pedal down so it was brighter and drove it home.
Glad you got yours sorted out.
If you go to bed smarter than you were when you woke up, someday you'll be a genius.....just ask Einstein! I learned some good lessons on this forum.
