0 Code U1255 sputters and dies
Last Post: Knuckles
0 Resistor vs Copper plug wires?
0 Rear rocker cover?
0 Ran out of gas.
14 Taking one for the team...
Last Post: quickstang87
0 Surging/lurching at low speed?
5 77 Ironhead custom, rear brake cable
Last Post: Slytat
0 Happy Birthday Yellow Scooter
0 1987 883 breather bolts are different?
0 Does titanium exhaust exist?
Last Post: tomaso
0 beware of buzzards
0 ironhead wrist pin bushing size?
6 73 Sportster Starts, Runs Fine, Dies
Last Post: Island Dude
0 Anyone
Last Post: MotorPsycho9
0 My 1250 to 1275 build
0 08 XL1200N quick question/confirmation: 18" / 19" Rear Wheel On '08?
0 Photos: King Peanut or Regular Peanut tank?
Last Post: Lone Rider
0 Repo S&S E Carbs ... any good?
Last Post: Scott
0 Flame's New 1989
Last Post: VaFish
0 In a crash: Lucky to be alive
0 Best Bang for your Buck Exhaust option?
Last Post: priell3
Last Post: alaxjordan0
0 Chasing my tale with electrical issues
0 Brembo Front Brake Conv.
Last Post: SuicideCharley
wallylach (68), cob (65), decman (63), djhannu (57), Vaughn, irishhog (50), dangjalopy (46), earthoverdrive (41), edman87k5 (40), 79iron (37), mr_anti_chrome, jessman14241 (34), jakevandike (28)
View Poll Results: Crankshaft Failure
Yes : synthetic oil 15 7.28%
Yes : dino oil 14 6.80%
Yes: around 30,000 miles 11 5.34%
No : no problems 174 84.47%
Multiple Choice Poll. Voters: 206. You may not vote on this poll
Old 27th December 2007
Roadster_Rider's Avatar
Roadster_Rider Roadster_Rider is offline
Other Motorcycle Model: Victory High-Ball
Roadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura about
That damn nut takes 280 ft pounds(if I remember right). Take it apart and try again with this.
I just cut down a piece of brass to jam the gears, I'll go measure it...
To get the individual sockets you'll have to go to sears, if you're a cheap bastard like me you can take the stuff back when you're done.
Edit-
It's about 4" by 1.5" and it was about perfect. Use brass or aluminum so as to not damage the gears. This was on my mother's 05 BTW.
Cory
midnitewolf's Avatar
midnitewolf midnitewolf is offline
Sportster/Buell Model: XL883 Sold
Other Motorcycle Model: FXDB Street Bob
Other Motorcycle Year: 08
midnitewolf is on a distinguished roadmidnitewolf is on a distinguished roadmidnitewolf is on a distinguished roadmidnitewolf is on a distinguished roadmidnitewolf is on a distinguished road
Edit-
This is giving me some hope , it sounds like a loose crankshaft nut is more common than a bad crankshaft . I was thinking of using a piece of 2x4 to jam it
Mark
Midnitewolf
08 fxdb Street Bob
[img]http://img85.imageshack.us/img85/3873/newbikeoo0.jpg[/img]
Four wheels move the body. Two wheels move the soul.
:pgrflag:
It could splinter off in there and it would be very difficult to jam it.
Harley sells the piece to jam the gears if you can't make one yourself.
There is definitely hope for an easy fix!
Oh, I also heard of using a 4" brass door hinge, that would be acceptable.
Thanks , I will be taking it apart and checking it again
I should be able to reuse the new gasket again so all
I'll need is a qt of primary fluid .
Old 29th December 2007
milmat1's Avatar
milmat1 milmat1 is offline
Sportster/Buell Year: 06
Did ya get the ole girl back on the road ?
I Tink the Server Clock is Toast !!
Phillthy's Avatar
Phillthy Phillthy is offline
Sportster/Buell Model: 1200R+
Phillthy has a spectacular aura aboutPhillthy has a spectacular aura aboutPhillthy has a spectacular aura aboutPhillthy has a spectacular aura aboutPhillthy has a spectacular aura aboutPhillthy has a spectacular aura aboutPhillthy has a spectacular aura aboutPhillthy has a spectacular aura aboutPhillthy has a spectacular aura about
Mine has had the front conrod go sloppy on the crank at 62k km so around 35k miles. It is a shame that S&S don't make a new crank to fit the rubber mounts yet.
I took the primary back off and the crankshaft nut is tight
so now I need to check my options
Have you fixed it yet or are you riding it with a loose rod ?
Phillthy's Avatar
Have stripped it down and waiting on HD to comment. See thread "Motor SHIT itself, letter to HD" is the latest.
Old 10th January 2008
I traded it in on a 08 Street Bob
