Last Post: drumbrake
Last Post: Jarlaxle
Last Post: T_worth
Last Post: Bama Lee XLC
0 Shipping woes
0 Who's still riding???
0 In Tank Oil Filter?
0 Valve guide replacement SOP
Last Post: NHPS
0 04 Battery Cover on a 95
Last Post: F1J1
Last Post: sltm1
Last Post: Jarlaxle
0 What oil temp do you run
Last Post: JKKO
0 Bushing alignment
0 Cometic gasket set part # ?
Last Post: T_worth
0 Posting Pics
Last Post: kmul
0 Help please!?!?! (Unidentified Spacer)
Last Post: bimbo
0 stress killer
Last Post: Yakcm2
0 ***DK Custom-Announcing The 5th Annual Internet Bike Contest***
0 ***DK Custom-SEE & BE SEEN-LED Front & Rear Lighting***
Old 25th July 2018
juzyHD's Avatar
juzyHD juzyHD is offline
Sportster/Buell Year: 1986
I found two version.
this: http://www.skf.com/group/products/be...tion=6009-2RS1 which it looks like it has a deeper groove,
and this: http://www.skf.com/group/products/be...on=W%206009-2Z which it looks like a 'normal' groove. Which do you think is better?
Old 25th July 2018
Sportster/Buell Year: 1988
Normally you fit the 6009-2z with metal shields so it can get gear lube.
The explorer version will also be marked 6009-2z but designated Explorer:
http://www.skf.com/uk/products/beari...nation=6009-2Z
Note the Explorer has a higher load rating
Old 25th July 2018
juzyHD's Avatar
Well I can open it on one side. The stock one was sheelded only from stator side.
Old 25th July 2018
Mine is 2Z - two shields. I doubt it would make much difference if it is z or 2z. The main issue is the condition of the bearing. For what it's worth, the SKF engineers advised me not to use rubber seals in the trans.
