0 Modified heads
0 79 Tranny
0 1200S cam comparisons
Last Post: Saint666
0 Valve adjustment question
5 Summer time heat
0 Drag Specialties Headlight Housing + LED?
Last Post: Eddie Lives On
Last Post: Bone
0 Front cylinder noise
0 How do you upshift?
0 WTF Happened
Last Post: oupa
0 Spectro STL 75W140
Last Post: VaFish
0 Buell lightning
Last Post: Stickr
5 03 XlH1200 Best top end commination.
Last Post: Saint666
0 Bendix / Zenith questions
Last Post: DirtyHarry68
0 Lacing a 21 inch wheel to a 19 inch hub
Last Post: 72 Ironhead XLH
0 1981 ironhead xlh PROJECT
Last Post: Wilkinson949
0 900 dual carb front head
Last Post: thefrenchowl
0 Hi from NY state
Wild One, Bugs (66), Blazer (63), OnDVirg (63), Buggyboy (60), TheChimp (45)
Old 30th May 2009
FoxsterUK's Avatar
Default A picture that justifies my cam choice
This is data on the last 3-1/2 hours of riding my bike. Its been a mix; with some sharp acceleration, some street cruising, some highway cruising and some 100mph+ pulls.
You can see that most of the riding takes place at 2000-3000rpm with hardly anything above 5000rpm. So I'd say my choice of Andrews N3 cams was pretty much spot on. If I had chosen some 'hotter' cams that pushed the power to 5000+rpm then I would have put the power just where I least needed it.
I'd say this is pretty typical for a lot of riders and good evidence against over-camming.
Fox
I had an '05 1200R.
Old 30th May 2009
snowman's Avatar
snowman snowman is offline
I have to agree with your findings, Fox...
This looks like a classic street bike pattern...
--Russ--
U.S. Army Veteran
***RIP***
--Mr. JIMI
--JOHNNY G
--BryanEOD
Old 30th May 2009
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
Exceptionally relevant information for folks considering cam choices..
I've stuck this, for future reference..
Thanx!
~Chuck
Occam's Razor...
XLF Tuning Stickies
Old 30th May 2009
Lenster's Avatar
Lenster Lenster is offline
Lenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond repute
With hotter cams, would you simply spend more time in the upper RPM range because that's where the power would be?
I think we humans adapt somewhat to the machines we use...........
Lenster's 1250 2006 XL1250C, Hammer Crush Heads, 15 Degree Pistons, 10.5:1 CR, S&S Roller Rockers, Fixed Length Pushrods, Jim's Powerglide II Hydraulic Lifters, RedShift 585 Cams, Energy 1 Clutch w/ 15% Stronger Spring, Hammer Performance Billet Intake Manifold, Mikuni HSR 45 (25 Pilot, 157.5 Main, 96 Needle 2nd Clip from top, Y6 Needle Jet), Offset Crush AC, Cobra Power Pro HP 2:1 Exhaust and a Daytona Twin Tec TC88A with a Kickass Map by Rico 05R.
Old 31st May 2009
blakjak's Avatar
blakjak blakjak is offline
Sportster/Buell Model: Honda CBR 929RR
blakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura about
Nice!!! Definitely good info. Have to try this with my ignition.
Old 31st May 2009
floorit's Avatar
floorit floorit is offline
Sportster/Buell Model: 1200c
Other Motorcycle Model: Honda XR250r
Other Motorcycle Year: 90
floorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to behold
I also have the N3's. Very happy with my chioce.
Old 31st May 2009
Lenster's Avatar
For referrence, this is my chart from over 120 hours of operating time.
I think there is some useful info here, although I have to question the validity of some of it, since in the last 120 hours, I'm sure I've hit the rev limiter several times (set at 6250 - 6300) and never have I hit 7468 RPM. Plus, how can I have .39 seconds at the RPM limit yet have no time recorded from 5000 - 6500 RPM?
I'm running stock W cams. I'm wondering if so much of my time above 2999 RPM has anything to do with the reversion of my 2:1 pipe and me riding around it.
Old 31st May 2009
Gojira's Avatar
Gojira Gojira is offline
Bike Builder
Sportster/Buell Model: 883r
Other Motorcycle Model: cb750
Other Motorcycle Year: 1974
Gojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the rough
allso running a 2-1 and i ride at 3000+rpm most of the time,80mph is 3900-4000rpm for me though,only in the first 3 gears do i even try to ride under 3000rpm,1 and 2 gear are good for puttin around between 2000 and 3000
Old 1st June 2009
XLdaveR XLdaveR is offline
XLdaveR has disabled reputation
Elapsed time data in any given RPM range is only logged if you run for at least 30 seconds in that range. Thus if every time you start the bike, you only run for a total of 20-25 seconds in the higher RPM ranges, the value shows as zero.
I'm also showing 7468 Maximum engine revs, My limiter is set at 6000rpm and always has been...
Old 1st June 2009
That pretty much sums up how I ride as well, With "Hotter" cams the engine revs up so fast your flat out changing all the time
What the chart doesn't show are the times your getting on it. Like taking off from a stop light, taking it to the redline in every gear. We're not spending enough time in the higher revs before changing gear for it to be logged in the statistics. What its showing are the times were cruising at a somewhat steady throttle position
