0 Misfire 02 883
0 headlight upgrade
Last Post: Nrg2brn
Last Post: oupa
0 Early Ironhead oil cooler? Filter upgrade?
Last Post: curiousgeorge
Last Post: motorend
2 Humble pie
Last Post: mac93
0 Safe Max Rev Limit stock engine Roadster 2017
0 My 1250 to 1275 build
Last Post: Bryan1976
0 EFI 101 Thread
Last Post: Turbo Sporty 48
0 Ran out of gas.
Last Post: Calcustom
0 Amputee Sporty Springer Trike Conversion
10 waited all year for this moment its on!!
5 Favourite grips?
Last Post: Jason's Sporty
0 Weight reduction TRUTH, not fiction
0 is a buell a harley
Last Post: Crash7557
0 Flat tracker pics
Last Post: Gary E
0 Clutch Spring plate poll
0 Helping a friend...
Last Post: MDT
0 old member new thoughts
Last Post: clif02
0 Ever been pulled over?
Last Post: Sprtstr1200s
0 08 XL1200N quick question/confirmation: Year Of Fender For ECM Relocation?
Last Post: Skhunt
0 08 XL1200N quick question/confirmation: Later Year ECM On An '08?
Last Post: Skhunt
0 08 XL1200N quick question/confirmation: 18" / 19" Rear Wheel On '08?
Last Post: Skhunt
Old 1st June 2009
arab1302's Avatar
arab1302 arab1302 is offline
arab1302 is a jewel in the rougharab1302 is a jewel in the rougharab1302 is a jewel in the rougharab1302 is a jewel in the rougharab1302 is a jewel in the rougharab1302 is a jewel in the rougharab1302 is a jewel in the rougharab1302 is a jewel in the rougharab1302 is a jewel in the rougharab1302 is a jewel in the rougharab1302 is a jewel in the rough
Originally Posted by XLdaveR View Post
I'm also showing 7468 Maximum engine revs, My limiter is set at 6000rpm and always has been...
I would bet you that the 7468 is some sort of default value inside the module. Even the .39 sec at REV limit is probably a default value. As another poster stated, you would need to spend 25-30 seconds at any RPM level for it to register, so how can it tell you that you spent less than a half second at the REV limit?
Old 1st June 2009
XLdaveR XLdaveR is offline
XLdaveR has disabled reputation
That's what I was thinking also, but I have been informed by DTT that 7468 is the highest value recorded for maximum engine revs. There explanation was that we have probably messed a downshift and over revved the engine, possibly even higher the 7468! I'm going to ask them for a password to clear the Statistic data and keep a closer eye on it.
You have to spend 30 seconds or more at any given rev for it to be logged. The time at rev limit is measured in seconds for more accuracy
Old 1st June 2009
Lenster's Avatar
Lenster Lenster is offline
Lenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond repute
That's what I was thinking also, but I have been informed by DTT that 7468 is the highest value recorded for maximum engine revs. There explanation was that we have probably messed a downshift and over revved the engine, possibly even higher the 7468! I'm going to ask them for a password to clear the Statistic data and keep a closer eye on it. You have to spend 30 seconds or more at any given rev for it to be logged. The time at rev limit is measured in seconds for more accuracy
When you get the password, would you mind sharing it? I don't understand why they keep it "under lock and key".
Lenster's 1250 2006 XL1250C, Hammer Crush Heads, 15 Degree Pistons, 10.5:1 CR, S&S Roller Rockers, Fixed Length Pushrods, Jim's Powerglide II Hydraulic Lifters, RedShift 585 Cams, Energy 1 Clutch w/ 15% Stronger Spring, Hammer Performance Billet Intake Manifold, Mikuni HSR 45 (25 Pilot, 157.5 Main, 96 Needle 2nd Clip from top, Y6 Needle Jet), Offset Crush AC, Cobra Power Pro HP 2:1 Exhaust and a Daytona Twin Tec TC88A with a Kickass Map by Rico 05R.
Old 3rd June 2009
Hmmm, they will only release this information to corporate clients after they sign a non-disclosure agreement.
In the mean time here's another chart to ponder over,
You would think that I spend most of my time in the 2-4000rpm range after looking at this. So I'll also included a sample of what I would describe as an "average ride" for me.
I like my N4 cams
Old 3rd June 2009
Lenster's Avatar
Does this mean they wouldn't give it to you?
Old 8th December 2010
Sportster/Buell Year #2: 2008
Default N4 Cams
I like my N4 cams
N4 is what I was thinking too. However I saw a dyno graph of the N2 vs N4 cams on the same bike. The chart overlay looked like mirror images(opposites) up to peak HP and Torque. The N4 was on top above 4250 or so rpm and the N2 was on top below that engine speed. http://www.sportster.org/wp-content/...10/N2vsN41.jpg
I was thinking it sure would be nice to get variable valve timing to get both N2 low rpm power and N4 upper rpm torque.
I guess it all depends upon where your engine spends most of it's useful life.
Nzhasher's Avatar
Nzhasher Nzhasher is offline
Sportster/Buell Model: Sportster Custom 1200
Sportster/Buell Model #2: Stg 1, Remus pipes N4's
Nzhasher has a spectacular aura aboutNzhasher has a spectacular aura aboutNzhasher has a spectacular aura aboutNzhasher has a spectacular aura aboutNzhasher has a spectacular aura aboutNzhasher has a spectacular aura aboutNzhasher has a spectacular aura aboutNzhasher has a spectacular aura aboutNzhasher has a spectacular aura aboutNzhasher has a spectacular aura aboutNzhasher has a spectacular aura about
Yep, Though I selected the N4 because its 'usefull life' is spent saving my life.
The N4 for me gives me a handfull of horses at Euro highway speeds, and allows me to get out 'o' the way of trucks in merging lanes at 80+
Oh - and its great for low gear twisties when shes wound right out..
Default Increased Compression?
Nzhasher,
Did you increase the compression also?
What to? Anything else changed?
It is easy to forget there are so many more outcomes when multiple variables are changed.
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
I understand this is dependent on the parts used but, how much power is gained by increasing the compression ratio on a 1200cc 2007 to 10.5?
Nzhasher's Avatar
Nzhasher,
I have not fiddleds as much as some!
N4s
Hurricane AC,
Groinked pipes
PC5
M
