Last Post: T_worth
0 04 Battery Cover on a 95
Last Post: stylEMon
0 In Tank Oil Filter?
Last Post: Coz
0 Bushing alignment
0 Free Shipping on Suspension from DK Custom - Limited Time
0 Limited Time- Savings Code on Comfort Parts from DK Custom
0 Limited Time- Stage I Savings Code from DK Custom
0 ******* usps
Last Post: rurlndum
0 Who's still riding???
Last Post: bplinson
0 Stabliser Tie-link 16232-04
Last Post: Vohnsen
0 Top End Not Oiling
Last Post: Vanmor
0 Winter Sucks
0 Her indoors
0 Big Bore '03 883R :)
Last Post: t120r
Last Post: drumbrake
Last Post: Jarlaxle
Old 8th December 2010
steelworker's Avatar
Other Motorcycle Year: 2016
The charts are interesting, and I'd agree that most cruising on normal roads is done at around 3000rpm, but if the system only records periods of more than 30 seconds spent in a given rev range it's of limited use in choosing cams. Whilst accelerating through the gears, I'd suggest one would rarely spend 30 seconds or more within any given 500rpm rev range until one is up to cruising speed.
cowboy770's Avatar
cowboy770 cowboy770 is offline
cowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of light
Thumbs up
I like my N4 cams[/QUOTE]
+1
Strangeman of the Gas Guzzlers MC
04 1200R N4 cams, custom A/C , stage 1 P&P, porker switchblades, Tc88a with Ricos Hooligan map, 185 main, 48 slow, and custom 5.2 gal tank. 3-1/2in extended forward controls, Enough about me, tell me about you.
XLdaveR XLdaveR is offline
XLdaveR has disabled reputation
Originally Posted by Sporty 48 View Post
N4 is what I was thinking too. However I saw a dyno graph of the N2 vs N4 cams on the same bike. The chart overlay looked like mirror images(opposites) up to peak HP and Torque. The N4 was on top above 4250 or so rpm and the N2 was on top below that engine speed. http://www.sportster.org/wp-content/...10/N2vsN41.jpg
I was thinking it sure would be nice to get variable valve timing to get both N2 low rpm power and N4 upper rpm torque.
I guess it all depends upon where your engine spends most of it's useful life.
48,
With the right pipe you could make more power everywhere with the N4's.
That chart is as old as the hills! You stock sporty would make more power than that!
Lot'a peep's will say they don't spend lots of time in the upper rpm's and cant justify hot cams.
Whatever, It's only 'cause they don't have the power there now. Stock cams full flat at 5K
Get it? When your bike pulls hard to 6000 or 7000 rpms you don't fell like shifting at 4-5K!
The more top end power you got, the more time your gonna spend there.
Old 2nd January 2011
J_68 J_68 is offline
Sportster/Buell Year: 01
J_68 is on a distinguished roadJ_68 is on a distinguished road
how do you get this data ? thanks
FoxsterUK's Avatar
It came off the after-market TC88A ignition unit I had on my Sporty. You can do something similar with the TTS and SEPST EFI programming systems.
Fox
I had an '05 1200R.
rottenralph's Avatar
I suspect my chart would be a little different. Mine would sit in the 4000 range. I don't like my n8 cams but they were cheap. I prefered my bike with the 536's. I suppose I will eventually buy a set of 536's again.
Old 4th January 2014
jimmydee's Avatar
jimmydee jimmydee is offline
Other Motorcycle Model: KDX 200
Other Motorcycle Year: 1989
jimmydee is a splendid one to beholdjimmydee is a splendid one to beholdjimmydee is a splendid one to beholdjimmydee is a splendid one to beholdjimmydee is a splendid one to beholdjimmydee is a splendid one to beholdjimmydee is a splendid one to beholdjimmydee is a splendid one to beholdjimmydee is a splendid one to beholdjimmydee is a splendid one to beholdjimmydee is a splendid one to behold
That's more of a personality test than a cam choosing tool.
____________________________________________________________________________________________________________________________________________________________________________ 2006 XL1200C- Hammer Perf. 1250 kit w/ Crush ported heads, 1.900 intake valves, 1.615 exhaust valves, 560 cams, 30 deg. reverse dome pistons, Mikuni HSR45, SE heavy Breather, Hammer billet manifold, TC88A ignition, Samson Powerflow 3, Ricor vibranators, Superbrace, Avon air grips, Ricor shocks, Killer map by Rico, Michelin Commander II s., Traxxion Dynamics AK-20 fork cartridges. Oil leak.
Sportster/Buell Year #2: 2008
Yes, key is that power is there for when it is wanted.
If 3 Tuesdays from next Wednesday you want to go full screech, so be it.
If riding like a saint will impress a sweet young cop, easy does it.
Old 5th January 2014
the thread is from 2009. I am sure he probably has a much more balanced opinion 5 years later.
FoxsterUK's Avatar
Five years? Wow, how time flies.
Not had the Sporty for a bit now but I'm still picking cams that put the power where I use it rather than because they make peak power at some stupid RPMs that I hardly ever use.
