0 Code U1255 sputters and dies
Last Post: Grumpy-Biker
0 Rode today, 10 days post op.
Last Post: farmall
0 Shoulder rotator cuff problems
Last Post: farmall
6 Calling all musicians
0 Repo S&S E Carbs ... any good?
0 Does titanium exhaust exist?
Last Post: farmall
0 CV conversion help
Last Post: farmall
0 81 XLH Starter Wiring
Last Post: owlsplace
0 answer with a question game
0 (Do) (Are) Loud Exhausts__________.
Last Post: Eddieblz
0 Wisdom of an older man!
Last Post: Eddieblz
0 Loose solenoid bolt
0 Leather or Denim Vest//Another useless poll
Last Post: priell3
0 got pulled over the other day....
Last Post: Campsurf
Last Post: spamer80
0 Starter/solenoid issue
Last Post: Dshank14
Last Post: Yakcm2
0 In a crash: Lucky to be alive
Last Post: Bored now
0 What oil temp do you run
0 Things to Ponder game
0 stress killer
0 Amputee Sporty Springer Trike Conversion
0 Timing / Piston install questions
Last Post: 11B40
0 08 XL1200N quick question/confirmation: 18" / 19" Rear Wheel On '08?
WinXP (68), Maggie (62), grancan1 (54), SRKASM (48), metalmessiah, o113attitude (44), stinkynate (36), wingman_214 (35)
Old 23rd March 2009
bplinson's Avatar
bplinson bplinson is offline
The XL Forum Host
Sportster/Buell Model: 883>1250 Stage 2
Other Motorcycle Model: Road Glide
Other Motorcycle Year: 2011
bplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond repute
Try here: http://www.xlforum.net/vbportal/foru...t=31258&page=3
AMA #961454
Old 27th September 2009
grfktatoo grfktatoo is offline
grfktatoo is an unknown quantity at this point
What if the engine was moved after the cams were removed? How would I set it back. I have torn down the engine several times trying to get the cams in the right location. The bike ran perfectly fine before teardown and now backfires and misses. I set the cams exactly as the book states but there is no reference to where the pistons need to be when aligning the marks. I don't know hwat else it could be.
Old 11th March 2010
bigpun0044 bigpun0044 is offline
bigpun0044 is an unknown quantity at this point
I can see the rationale about the anti-seize causing the cam cover bolts to come loose. Would blue threadlocker work to both prevent galling and keep the bolts secure?
Old 11th March 2010
Folkie's Avatar
Folkie Folkie is online now
Brass Nut
Sportster/Buell Year: 2015
Won't Loctite just break down with the heat of the engine?
Folkie
South East England Riders
Old 11th March 2010
xena's Avatar
xena xena is offline
Assistant Administrator
Dunno bout that. My stock breather bolts
were loaded with blue when I removed
them years back and the engine gets
pretty hot up there at the heads.
XLF Rules/Guidelines
XLF Guidelines II
1212 Conversion 10:1 CR
SE 497 Cams
Python 3 Slip ons
TC88A running Xena's Black Panther Map
My 1212 Conversion Thread
XL Forum Members Map
Old 11th March 2010
Folkie's Avatar
Brass Nut
Was it still coloured blue? Once it sets it turns white.
Old 11th March 2010
jessearias's Avatar
jessearias jessearias is offline
Sportster/Buell Model #2: XR-1000
Sportster/Buell Year #2: 1984
jessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nice
Default Excellent post
Excellent post. Very detailed and excellent instructions.
Should be made a sticky.
[FONT="Arial"] Jesse :smoke [/FONT]
2002 XL1200S "The Black Beauty" NRHS 1250 kit CI, NRHS Stage 1 TS heads dual plugged, NRHS Hurricane Air Filter, SE 536 cams, Rich Products Thunder header, 42 Mikuni, Daytona Twin Tec ignition w/ Dyna coils. 97.4 HP, 85.5 Torque 1984 XR-1000 S&S Crank/rods w/windage tray, Vision Grinding Cylinders, Arias 11:1 compression pistons, Andrews XR-1000-1 cams, Baisley modified dual plugged heads, Rich Products Thunder header, 38mm Delortos, Daytona Twin Tec ignition w/ Dyna coils. (the never ending project but, got a 66 Barracuda drag car sucking up all the funds and time)
Old 17th April 2013
efinmirical efinmirical is offline
Sportster/Buell Model: xl 1250 r
Sportster/Buell Year: 04
efinmirical will become famous soon enoughefinmirical will become famous soon enoughefinmirical will become famous soon enoughefinmirical will become famous soon enoughefinmirical will become famous soon enoughefinmirical will become famous soon enoughefinmirical will become famous soon enoughefinmirical will become famous soon enough
little late to the party here, but, how about getting those pics posted back up?!!
Old 17th April 2013
xena's Avatar
Don't think that's going to happen but check out the sticky for Phillober's conversion. He outlined every step including cam install. I followed it when I put mine in.
Sent from an iPhone Star-Trek Communicator
Old 25th April 2013
MEMECH MEMECH is offline
Sportster/Buell Model: 883Xl
MEMECH is an unknown quantity at this point
Im in the same bat as grfktatoo , cams came of doing a simple cover swap and cams where nor alligned, dont know the position the pistons where and bike was moved a bit , dont know where to go about at this point, any ideas?
Thanks
Similar Threads
pics of my 1st complete build lucky13 Chopper & Bobber Talk 61 30th September 2017 18:04
04-05 Cam Install How-To with pics just posted: Turbota Sportster Motorcycle Motor - Top End 9 19th October 2007 01:07
Pics of my roadster - winter projects complete! Gone Sportster Motorcycle General Discussion and Problems 21 10th March 2005 01:06
anyone install a hypercharger on a 04 1200? vetthed Rubber Mount Sportster Motorcycle Talk (2004-2006) 15 7th March 2005 13:47
FXSTB 'Night Train' SE Aircleaner Install (pics) Turbota Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 15 26th November 2004 02:06
