Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Suspension, Frame, Forks, Fuel Tank, Oil Tank, Fenders
0 Sportster Fork Upgrade
Last Post: Redbeard2
12 Crankcase breathing?
0 Adjusting Drive Belt While On A Lift
0 Do you use a bike cover?
Last Post: Old Rocker
0 Rear sets?
Last Post: bordens
Last Post: Vic8028
0 "S" model specific Q&A
0 Ground Up Beginner Build
Last Post: Paul.W
0 Turbo Iron 883
Last Post: Cj_
Last Post: PetesPonies
Last Post: Blackmagellan
0 Clutch springs
Last Post: BigMek
0 Coil polarity
0 New Guy with Experienced Bike
Last Post: Bikeaholic
0 Info needed on mini sumps.
0 primary cover
Last Post: smoggy
Last Post: davesz1r
0 Chinese S&S carbs
0 oil transfer valve
0 Tappet blocks and tappets
PEISprotster (68), 2009XR (66), Briank (61), bbj6635 (59), Reddog225 (48), larre1973, Irondrake77 (41), picowatt (40), Jeffrey99 (39), namesnick (39)
Old 19th February 2017
sml1226 sml1226 is offline
Default XB/XR shifter crank?
I bought some rearsets for my Roadster and I'm getting annoyed in dealing with trying to get the screwed up shifter crank replaced. I'm supposed to be getting a replacement, but I'm tempted to modify things regardless.
At this point, I'm questioning whether the XR and XB parts will work instead as both are easily obtained (easy enough anyway... the dealer about an hour away should be able to get both if I don't want to just order online) and have the potential to do what I'm after.
If anyone with an XR can tell me how far out that crank actually sits, that would be great. Trying to figure out if I can turn it sideways toward the derby cover and have it work out. Can't tell how big they actually are, as there's no good picture of the left side of an XR so I have no clue whether I can make it work.
Anyone with an XB that can give me any dimensions would be awesome too. That seems like it could work as well, but I have no idea as to actual dimensions. Not knowing how the XB cases are actually different doesn't help.
I imagine I could make either work with enough tweaking of things, but given the two significantly different options, if anyone can provide any, I'd really appreciate knowing what I'm getting myself into by pursuing either option.
Old 1st March 2017
It'd be nice to be able to just bump a thread without a new post. Anyway, anybody able to help?
