Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Styles > Dirt, Off-Road, and Adventure
Last Post: bordens
0 Carb starting issue.
Last Post: Billy1200
0 Be Careful Out There!
0 clutch issue
0 Mikuni Knock Off "REVEALED" !!!
Last Post: davesz1r
0 Ebay ****evil knievel bike****
Last Post: MnKevin
0 Coil polarity
0 Chinese S&S carbs
Last Post: T. Clark
Last Post: bordens
0 80 xl1000 oil not circulating?
Last Post: smilinbrad
0 Wont Fire up!
Last Post: Mission1
0 XR mutt race bike progress
0 show me your sporty next to an old or rural post office
Last Post: Hellbent_4
0 1998 883 spits and sputters at around 3000 rpm
Last Post: denguy
0 old style fender skirted
Last Post: Proteus
boblaine (85), mike wels (74), GaryR (64), cat5752 (53), Ocbuckeye (50), commandesc (45), vividblack05 (38), north_cack
Old 9th April 2017
Steve S. Steve S. is offline
Steve S. is an unknown quantity at this point
O.K. Thanks Big Al. Guess the search is still on!
Old 9th April 2017
Big Al's Avatar
Big Al Big Al is offline
Sportster/Buell Year: 1989
Other Motorcycle Model: Harley FLH1200
Other Motorcycle Year: 1974
Big Al has a reputation beyond reputeBig Al has a reputation beyond reputeBig Al has a reputation beyond reputeBig Al has a reputation beyond reputeBig Al has a reputation beyond reputeBig Al has a reputation beyond reputeBig Al has a reputation beyond reputeBig Al has a reputation beyond reputeBig Al has a reputation beyond reputeBig Al has a reputation beyond reputeBig Al has a reputation beyond repute
The only place I've seen the instructions are with eBay sales of NOS Red Wing forks...
Old 11th April 2017
tallsteve tallsteve is offline
Sportster/Buell Model: VRSCR
Sportster/Buell Year: 08
tallsteve is an unknown quantity at this point
Originally Posted by Big Al View Post
The only part I couldn't figure out was that cylindrical slotted spacer in the first photo, so I just left it out!
Is it the same diameter as the spring? I don't know anything about these forks specifically, but that looks like a classic fork spring spacer for forks of that era. Rather than manufacture hundreds of different spring lengths, they made a few standard lengths and add spacers to suit.
If so, I would say that the spring goes in the fork, then the top hat shaped washer (locates in the spring), then the spacer, then the flat washer. You definitely need one of the washers between the spring and the spacer, don't have them edge to edge. Finally, fork cap in on top (mind your eyes if the spring is strong, won't be the first to get a black eye from a wayward fork cap).
Old 13th November 2017
Big Al's Avatar
I found some useful information on these forks yesterday, taken from the product catalog apparently - at least I won't have to guess the hydraulic fluid capacity...
RW-HX-LB
Length - 32-5/8"
Travel - 7-1/8"
Stanchion Dia - 34mm
Standard spring rate - 29/43/56lbs per in.
Minimum 1st position - 20lb
Standard 2nd position - 33lb
Maximum 3rd position - 46lb
Spindle Dia - 15mm (not supplied)
Hydraulic fluid per leg - 192cc 6-3/8 fl oz.
Slide Dia - 1-7/8"
