0 Ironhead carbs
0 fork tube cap
Last Post: Heff
0 Another Wrap Post
0 Graduated to Ironhead
0 Hammer 1250
5 1988 xlh1200//// dynatech2000i shorting/grounding help
Last Post: jtb%sporty
0 Sticky Ironhead trans
Last Post: BigLerowski
0 Top end failure
Last Post: Mission1
0 Chinese S&S carbs
0 Info needed on mini sumps.
0 yost power tube guy
0 XL Forum T-Shirts ?
Last Post: Flying Monkey
0 HF bike lift
Last Post: Rgm883
0 No spark
Last Post: awright2009
0 Piston and cylinder condition
Last Post: duffy
0 Bikers choice main jet threads
0 Cleaning carbon build-up
0 Don't Think I Ever Did This
GWR (68), Helimad (66), dragon62 (58), metromix (58), Repohio (57), acenorm (52), reblu (44), jesterdoc (44), glucky7 (42)
Old 9th April 2016
That's very interesting information. I'd like to use this for the wiki.
Old 11th April 2016
Scuba10jdl's Avatar
Sportster/Buell Year #2: 1972
Originally Posted by jstoll View Post
hey there... I put some SE 497 cams in with a 1250 kit and Im noticing my lifters are noisier cold.. when the engine is fully warm its quiet like it was stock.. when I put in the cams I just re used the old lifters.. they are used cams ... the noise isent horrible or even concerning... its like they bleed down a bit and then the jugs grow as the engine warms up and finally they pump up as everything settles and its quiet as can be... one or 2 are a little louder then the others but like I said its not bad....also the cams Im running have the courser teeth (pressed on the drive gear from the W cams) and andrews states that the gears can produce what sounds like lifter noise...
the ramps are steeper on the 497 cams then the W cams... with the HSR42 carb I can actually hear the intake valves slapping shut at idle through the air filter :-)
Im thinking about running 850-1 lifters but I also notice some lifters for sportster and TC engines with a larger wheel and the lifter body is less closed in at the wheel end... whats up with these? anyone know if its better to run the ones with the larger wheel?
take care and thanks in advance for any input
JAK
I'm running Andrews N4 (same as the .497) with the same lifters as I used in this post. Clearance was fine for those. If you were to go to a much larger cam grind, then I would want to check the clearance and make sure the lifter body doesn't hit the lobe.
You're more than welcome to.
http://i.imgur.com/Oe4Ttw0.pnghttps://i.imgur.com/AFv3AMo.jpg?1
Old 7th May 2016
jstoll's Avatar
jstoll jstoll is offline
Sportster/Buell Model: XL1200Frankenbike
jstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant future
I thought it worth mentioning that I put the 875-1 lifters into my 05 XL with SE 575 cams and the pump limiters in the lifter in combination with the smaller base circle of the SE 575 cam got me valve lash when the engine was hot... I removed the pushrods and slipped the tappet covers out... removed the lifters and pried out the travel limiters and installed the clips from my stock lifters... the valve noise was then greatly reduced hot...I do have a fair amount of cam gear lash and noise with these cams though... they have the course teeth between the cams and fine teeth to the pinion....but I would go with the 850-1 not the 875-1 on an XL ...
have a great weekend :-)
JAK
[SIGPIC][/SIGPIC]
05 XL1200F
Frankenbike
Hammer 1250 11:1 30* pistons
Hammer Crush Head service
Mikuni HSR42
Hammer Impact Air Cleaner
SE 575 cams
XR crank
Energy One clutch
07+oil pump
Patriot Defender
TC88A with custom mapping
Old 7th May 2016
rocketmangb's Avatar
Jak
I run the 850-1 Lifters
Poor ole bike runs 114 MPH trap speed in the 1/4
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 29th October 2019
Scuba10jdl's Avatar
Thought I'd update this since I got a set of S&S Hi-Performance Lifters 33-5350. Below are the pics. Basically identical to the Harley A lifters and same oil metering valve as the Comp Cams and HD A lifter. Also update, the Comp Cams 850 lifters in my Evo have a little over 80k miles on them now and still going fine.
I have HD B lifters I'll get to eventually as well.
Old 10th May 2020
Diogenes415's Avatar
Sportster/Buell Year #2: 2000
Other Motorcycle Model: XL883C
An old thread but something worth considering:
https://www.youtube.com/watch?v=fMoRaHJRrhc
Nope, it's a Sportster.
Old 10th May 2020
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
All this is old news. So is the vid.
Yeah, some are using the comp cam 850s, but the Johnson Hylifts are a much better alternative.
Old 10th May 2020
kitabel kitabel is online now
Sportster/Buell Year: 1989
kitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of light
designed for AMC engines?
AMC lifters are .904" OD
Old 10th May 2020
99 and earlier are .904
Old 19th May 2020
Ghostdog's Avatar
Ghostdog Ghostdog is offline
Sportster/Buell Model: Sportster iron 883>1275
Sportster/Buell Year: 2016
Ghostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to all
Default Hylift Johnson
60 gunner , is it better to use the slow leak down hylift or the the regular ? Just wondering what part number . Thanks
Ghostdog 2016 iron883<1275 Hammer prefomance kit, energy one extra plate clutch, 15percent spring,N4 cams, ported 883 heads ,danmoto 2-1 exaughst ,Dynojet powervision tuner .
