Last Post: Oldmxdog61u
0 Transmission issues
Last Post: bobber58
0 WTB: 1996 Sportster stock-ish exhaust and mid controls
Last Post: PRICHMON
0 Keihin Butterfly crack
Last Post: jasnoc
0 Cut Wiring, no spark.
0 Chinese S&S carbs
Last Post: 11B40
0 Info needed on mini sumps.
0 Top end failure
Last Post: Mission1
0 Ironhead high speed cruise prob
0 First Harley - 1975 XL1000 Café Project
Last Post: Jcolleyoh
Last Post: SprtyXL
0 Rear Exhaust Tappet Mount Block
Last Post: knocknakilla
Last Post: james beam
Last Post: keithnh
0 Valve Lengths?
Last Post: motorhedmike
FORCE50 (68), marcus (55), gardkarlsen (50), dhoppe1 (42), Hagen (42), tdyer55 (38)
Old 19th May 2020
Sportster/Buell Year: 1991
Harley has top end sets and less inclusive rocker box sets. They're on Ronnies' parts fiches. On the cyl head or rocker box frame. It is nice having a set so you've got what you might need and you're not stuck chasing and/or waiting on a gasket to finish up.
Yes, my thoughts as well. Thank you for the information about HD complete rocker box sets, I'll give the local dealer a call today. I figured they probably had a set, rather than buying each piece individually. Nothing worse than having to make multiple trips for one issue.
John
Old 22nd May 2020
Well, according to my local dealer, they only sell a complete top end gasket set, not a separate rocker box set. Even worse, I can actually buy the individual gaskets from Ronnie's online cheaper than at my local dealer, even when shipping is factored in. Go figure. Not to mention time and gas involved in driving 20 miles to the dealer and back. Sad.
John
Old 22nd May 2020
I just used some Amazon points and ordered a Cometic rocker gasket kit, C9765, $35 delivered. Thanks to all!
John
