8 Inexplicable miss
0 Bandanas
0 Chinese S&S carbs
0 Top end failure
Last Post: Mission1
0 XR mutt race bike progress
Last Post: Scott
5 Eye Protection When Riding?
0 Ignition advice
Last Post: Rhode Warrior
0 1992 XL ignition explained
Last Post: Bwf347
0 New guy from IL
0 normal shifter shaft wobble
0 Front Brake Upgrade
Last Post: keithnh
0 Info needed on mini sumps.
Last Post: Randy_rots
0 Coil readings
Last Post: Billy1200
0 3/4” Axle Drum Brake ??
0 Inherited Ironhead
Last Post: Akdawg
0 Noise and rod play
Last Post: Vic8028
View Poll Results: Have you broken a drive belt (secondary drive) on your Sportster Motorcycle
Yes 381 30.46%
No 870 69.54%
Voters: 1251. You may not vote on this poll
Old 13th October 2005
rpcycle rpcycle is offline
Sportster/Buell Model: 1200c
rpcycle has disabled reputation
05 1200c, belt broke at 2500 mi. Was on my way to work, got to the bottom of my driveway, stopped to check for cars, went to take off in 1st gear and it wouldn't go. At first I thought it was the clutch or something. Looked behind me and saw the belt on the street. Had it towed to HD since I couldn'd push it back up the driveway. Repaired under warrenty. Have not done any radical driving or fast starts.
toe's Avatar
toe toe is offline
Sportster/Buell Model: 883C
toe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond repute
35000 miles, still have original belt........
Ed
The Only Y2K dual-set 883C
So Cal
crackers's Avatar
crackers crackers is offline
crackers is on a distinguished roadcrackers is on a distinguished roadcrackers is on a distinguished road
13months old, 30,000 km and the belt broke, clean snap between the teeth.
service guys told me only 1 belt is replace under waranty, even if the new one breaks in 2 days. (i'd like to see that hold up in court)
i'm still partial to sprockets & chains, and considering in OZ the belts are over $450 AUD each i'm considering going to a chain just for peace of mind.
(p.s. new chain on my old VF1000 was about $210 AUD)
cheers
crackers
thatbikerguy's Avatar
thatbikerguy thatbikerguy is offline
Other Motorcycle Model: Suzuki GS 750 L
Other Motorcycle Year: 81
thatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud of
'03 1200xlc orig belt still hanging in there...
expect the unexpected
2003 1200 XLC Sterling Silver/ Vivid Black
rottenralph's Avatar
Mine broke at about 20000. It was due to my pulley side bearing freezing up and welding itself to the axle. The bike slid a bit then the bolt spun in the swingarm as a rolled to a stop. It was really tough cutting the axle out with it in the frame. Used a air hack saw and a couple of blades.
1993 1200. Mine broke at about 20000. It was due to my pulley side bearing freezing up and welding itself to the axle. The bike slid a bit then the bolt spun in the swingarm as a rolled to a stop. It was really tough cutting the axle out with it in the frame. Used a air hack saw and a couple of blades.
wagoneer12's Avatar
wagoneer12 wagoneer12 is offline
Sportster/Buell Model: Sportster 883C
Sportster/Buell Model #2: Chopped XLH
Sportster/Buell Year #2: 1967
Other Motorcycle Model: 2007 Road King Classic
wagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the rough
11000 miles or so. Replaced under warranty.
1998, 883->1200, 18000 mi
Downshifting from 4th to 3rd, or 3rd to 2nd
on a group ride so not wacking it too hard
no obvious signs of wear or whatever
Old 14th October 2005
gronk62's Avatar
gronk62 gronk62 is offline
mostly harmless.. (sssm)
gronk62 has disabled reputation
Originally Posted by RoadKingMoe
A friend's belt on his '95 broke after a fairly long ride to the dealership. This was back in about 2002 and we just happened to be shopping there as he pulled in. It spooled off the bike and laid down gently in the parking lot as he was pulling into park. We told him he needed to buy a lottery ticket!
If its gunna happen, ya couldn't get much luckier than that
cadiero's Avatar
cadiero cadiero is offline
Other Motorcycle Model: BMW R1200RT
cadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to behold
Broke my belt at about 15K miles on an '04 1200C. Put a rock through it at about 11K miles. Knew it was gonna go, just trying to get the last mile out of it. Broke while downshifting before a stopsign.
www.oxidationtech.com
