0 Don't Think I Ever Did This
0 Hammer 1250
Last Post: davesz1r
0 04 brake upgrade question
Last Post: Calcustom
0 Primary Dip Stick?
0 Noise and rod play
0 1966 XLH...sort of
Last Post: Captain Johnny
0 Bikers choice main jet threads
0 Sportster 883 mini electronic speedo
Last Post: Doc308
Last Post: farmall
0 Spark Plug Indexing
0 1992 XL ignition explained
0 Counterfeit Mikuni Carbs
Last Post: davesz1r
0 front exhaust pipe keeps slipping off, help
Last Post: 67170
0 Stairman question
0 New Guy Here - Handlebar Question
Last Post: LLOYD883
0 yost power tube guy
0 FDR Drive pothole did this...if u can believe it
Last Post: LLOYD883
5 Is my timing correct?
Last Post: rerb
Last Post: Bone
debster, brknwng (72), TerryW (67), doc_davo (65), clh, Hanoverfiste (48), XL-DecentGlide (45), nobleff517 (45), joekangiser (42), scroggy (36), sgvrider (33)
ecm
Old 26th December 2013
99fritz1200c's Avatar
99fritz1200c 99fritz1200c is offline
Sportster/Buell Model #2: xl883l
Sportster/Buell Year #2: 2012
Other Motorcycle Model: softail heritage
Other Motorcycle Year: 2007
99fritz1200c will become famous soon enough99fritz1200c will become famous soon enough99fritz1200c will become famous soon enough99fritz1200c will become famous soon enough99fritz1200c will become famous soon enough99fritz1200c will become famous soon enough99fritz1200c will become famous soon enough99fritz1200c will become famous soon enough
Default Does the ECM have an adjustment screw?
My friends EFI Sportster has a small square flap on the front side of the ECM and under that is a screw marked "A" and "R". Anyone know what that adjustment controls? Our local discussion is that small adj there can help with low speed jerky issues...
Test rode the others but my 1999 1200c is the best motorcycle ever.
Sportster/Buell Year: 1991
So, asking about your "friends" bike? Heard that one before.
As to your "friends" questions:
Advance and Retard, perhaps? Static timing adjustment? That is probably not the problem.
Low speed jerky issues. That is most commonly referred to as PILOT ERROR. Learn how to engage throttle and clutch as a symphony of synchronicity and simplicity. Don't lug your Sportster!
John
Crosshairs's Avatar
Crosshairs Crosshairs is offline
Sportster/Buell Model: Its Black and shiny
Crosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond repute
Ive never heard of a screw being used to adjust an ECM.....but if there were such a thing, Harley would surely be the one to try it...
As far as the jerky issue..that's easily solved with a quality tuner such as the Power Vision
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: FLHP
Sportster/Buell Year: 2016
Sportster/Buell Model #2: Guzzi V7 Stone
Sportster/Buell Year #2: 2013
Other Motorcycle Model: 18 Guzzi V7D / 11 Duc 696
Some early non-feedback Webber-Marelli EFI systems (specifically found on some Guzzi California models) used an ECM that contained a screw that could be used to fatten or lean the mixture slightly.
Never heard of it on a Harley, though early EVO EFI WAS Webber-Marelli so it's possible.
cherokee jim's Avatar
cherokee jim cherokee jim is offline
Sportster/Buell Model: hugger
Sportster/Buell Year: 03
Other Motorcycle Model: fxdc/flhtcu
Other Motorcycle Year: 0907
cherokee jim has a reputation beyond reputecherokee jim has a reputation beyond reputecherokee jim has a reputation beyond reputecherokee jim has a reputation beyond reputecherokee jim has a reputation beyond reputecherokee jim has a reputation beyond reputecherokee jim has a reputation beyond reputecherokee jim has a reputation beyond reputecherokee jim has a reputation beyond reputecherokee jim has a reputation beyond reputecherokee jim has a reputation beyond repute
I love this forum oh so much and long time GI.
If it wasn't for my motorcycles I'd be flingin poo at the orderlies.
brianbbs67's Avatar
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 1970
Other Motorcycle Year: 1977
thetas funny idk who you are!
Thanks for the input. I have one friend who has done this and I see the cover plate in the manual. The manual doesn't label it and my friend with running issues hasn't looked at his yet. He can get it checked out with a tuner though.
Old 29th December 2013
Otter's Avatar
Otter Otter is offline
Otter is a splendid one to beholdOtter is a splendid one to beholdOtter is a splendid one to beholdOtter is a splendid one to beholdOtter is a splendid one to beholdOtter is a splendid one to beholdOtter is a splendid one to beholdOtter is a splendid one to beholdOtter is a splendid one to beholdOtter is a splendid one to beholdOtter is a splendid one to behold
Your low speed jerky issues are 80% mixture, and 20% behavior. Richening things up will make you a lot happier!
