0 Hammer 1250
Last Post: davesz1r
0 04 brake upgrade question
Last Post: Calcustom
0 Primary Dip Stick?
0 Noise and rod play
0 Don't Think I Ever Did This
0 1966 XLH...sort of
Last Post: Captain Johnny
Last Post: ronccc
0 Bikers choice main jet threads
0 Sportster 883 mini electronic speedo
Last Post: Doc308
Last Post: farmall
0 Spark Plug Indexing
0 1992 XL ignition explained
0 Counterfeit Mikuni Carbs
Last Post: davesz1r
0 front exhaust pipe keeps slipping off, help
Last Post: 67170
0 Stairman question
0 New Guy Here - Handlebar Question
Last Post: LLOYD883
0 yost power tube guy
0 FDR Drive pothole did this...if u can believe it
Last Post: LLOYD883
5 Is my timing correct?
Last Post: rerb
Last Post: Bone
debster, brknwng (72), TerryW (67), doc_davo (65), clh, Hanoverfiste (48), XL-DecentGlide (45), nobleff517 (45), joekangiser (42), scroggy (36), sgvrider (33)
advice, help needed, help please!!!, help!!, help- i have a question!
Old 12th January 2014
Rapturous Rapturous is offline
Sportster/Buell Year: 2012
Rapturous is an unknown quantity at this point
Default RSD Exhaust Pipes???
Hey all,
Has anyone ever installed the RSD 2-1 tracker Exhaust Pipes on a sportster?? I'm leaning towards it, and I wanna know how it'd work out for passengers. I know I can get the bracket to adjust the passenger pegs here:
http://www.hdforums.com/forum/sports...2011-48-a.html
But I wanna know if it'd be hot for them, if it'd get unbearable after an hour or two, stuff like that.
Thoughts?
maltesefalcon maltesefalcon is offline
Sportster/Buell Model: SuperLow
maltesefalcon has a reputation beyond reputemaltesefalcon has a reputation beyond reputemaltesefalcon has a reputation beyond reputemaltesefalcon has a reputation beyond reputemaltesefalcon has a reputation beyond reputemaltesefalcon has a reputation beyond reputemaltesefalcon has a reputation beyond reputemaltesefalcon has a reputation beyond reputemaltesefalcon has a reputation beyond reputemaltesefalcon has a reputation beyond reputemaltesefalcon has a reputation beyond repute
AFAIK this pipe is meant for solo seat setups.
Not just the proximity of the pipe to the rear passengers leg.
The actual exhaust outlet would be very close to their leg as well.
RSD pipe is made by Vance and Hines.
They have a few setups with 2 into 1 that would be more appropriate for two up riding.
Yeah . . . I figured. Well, maybe heat wrap will help with that, you think?
If anything, I'd need the passenger pegs to put my own feet on -- clip ons with mids aren't a greet feeling.
Maybe check out V and H Competition pipe?
Lightweight, aggressive compact look, but better suited to 2up.
But if you are going to rearset mounting as per above then Tracker would work. (Assuming no passenger)
It would? How do you figure?
Is it possible to put the passenger pegs on upside down, after all?
Just in case I have muddied the waters a bit.
Check out OCGreenmachine's post in this sub forum.
He has an RSD exhaust with rear sets that fits up pretty well.
This would only be practical in a single passenger arrangement.
If you are running a passenger, you can't use this setup.
Old 13th January 2014
I definitely will! Thanks!
I don't think I can go full on rearsets, but if I could at least have those rear pegs to put my feet on, I would be happy . . . I just hope they'll fit
Old 4th May 2014
Ocgreenmachine's Avatar
Ocgreenmachine Ocgreenmachine is offline
Sportster/Buell Model: XB12Scg
Ocgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud of
I ran the RSD Tracker 2-1 on my bike for about 8 months... It was a nice pipe with a nice sound. I had mid controls when I first installed it and then got custom Chainsikle rear sets. There is a passenger peg relocation kit if you run mid or forward controls sold through either Vance and Hines or RSD(can't remember which one sold it), so it can work for passengers. Take a look at the first part of my cafe racer post to see pictures of the RSD pipe on my bike before I swapped it out.
2009 Buell XB12S w/Hammer Performance 1250 kit. Dean Adams RT-XB1 exhaust, Custom ECM.
