Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Lubrication and Lubricants
Lubrication and Lubricants You guessed. Here is where everyone can argue over oil.
0 Adjustable main with mag
Last Post: davixlrtt
Last Post: mac93
0 Chinese S&S carbs
0 Mounting seat with out frame tabs?
0 Cleaning carbon build-up
0 Changing Battery(with factory Alarm)
0 Gasket placement
Last Post: Billy1200
0 Top end failure
Last Post: Mission1
0 What a birthday I've had
0 Mystery transmission piece??
0 Keihin Butterfly crack
Last Post: Tipofthelake
0 XR mutt race bike progress
Last Post: supermotolew
0 Info needed on mini sumps.
Last Post: mrmom9r
0 Don't Think I Ever Did This
Last Post: Veeflys
0 Hammer 1250 kit with fp3
Last Post: Pagey
0 Sticky Ironhead trans
0 Inherited Ironhead
0 HF bike lift
Last Post: BigLerowski
0 Graduated to Ironhead
0 Cutting Out Cracking Popping, Etc, After Fully Warmed Up
Last Post: jharback
Old 9th November 2014
taco taco is offline
Sportster/Buell Model: xl883 iron
Sportster/Buell Year: 2014
taco has disabled reputation
hey guys I am new here so don't chew my arse to bad , but been lurking here and there since I bought my 2014 883 iron in august, well I have had carry over pretty bad with only 1700 miles so I took it back to dealer 2 weeks ago and they blew me off I think (kept it for couple days and said nothing wrong just checked oil level and took it for ride) they told me running it hard would do that. I don't think I rode it that hard. any way since this thread was still recent I thought I would jump in and say thanks for info I got 20-50 syn i'll ride that this winter 1/2quart low to see if that helps come spring i'll go straight 50 1/2quart low. something has got to happen brand new bike and I had oil running down side of engine yes it was coming out of air box. I have rode twice since then(dealer and lowering oil) and nothing leaking, will monitor to see how MY bike needs to be kept and ridden. I know it is a cruiser not a sport bike but shame if I gotta ride like an old man
i'll try to be less wordy next time
Graywolf Graywolf is offline
Just an added comment to this thread - the oil leaking from the air cleaner might not be the only source. I had oil getting on the side of the bike and could find no leaks. It usually happened when running the Interstate highways for a while at high speeds. Found out it was coming from the primary vent line that terminated on the right side above and forward of the rear wheel. I bought the 01 used and not real sure if that vent line should have ran on back or not. I added a short piece of hose and ran it on to the rear of the bike. No more oil down the side! It wasn't enough oil venting to have any effect on the level in the primary. It was only some light oil mist, but it doesn't take much oil to make a big mess.
That might be something to check if you can't find any other source for the mess on the side of the bike.
Graywolf
Old 10th November 2014
DK Custom's Avatar
Sportster/Buell Model: 883L
Originally Posted by rejeanprimeau View Post
One trick I've learn from a girl friend : she use a sanitary serviet aka as Kotex at the bottom of her air cleaner, she swear not a single drop of oil get pass it. She say you have to change it less often than a woman will do. Beat all the AC recommendation I've seen so far. LOL
That is true. Bikers have been using that trick for decades, BUT, here are some pictures showing what happens when all of that oily mess goes back into the motor instead of being vented into the atmosphere.
Click HERE for for New Videos & Some COMIC RELIEF in this strange new world.
www.DKCustom.com
Phone: 662-252-8828
Text: 662-420-4891
DK Custom YouTube Videos
Lots of Photo's at Pinterest
Rollbar's Avatar
Rollbar Rollbar is offline
Sportster/Buell Year: 1990
Rollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud of
WoW - Thanks for the pic.
DK Custom's Avatar
Yeah, its amazing how much venting to the atmosphere can help an engine.
Rollbar's Avatar
Hey DK Thanks for all the great info / help
rejeanprimeau's Avatar
I run an external horse shoe breather with indexed bolts running directly under the bike.
Tell the guy running the cylinder on the picture number 2 to richen his AFR, you can see is having a spot that will turn into a hole if he still run his bike that lean.
Old 11th November 2014
AnaChris's Avatar
AnaChris AnaChris is offline
Sportster/Buell Model: 883xlc/1250
Other Motorcycle Model: FLHRCI
AnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant future
My Sporty hits 5th gear at 115mph keep at it buddy!
Old 15th May 2015
hey sorry to bring this thread back up with out researching forum more but after a few rides with a little oil drip had big time blow bye. did about a 9 hour round trip to Virginia mountains and back to county by the bay, had a very little spittle, drove to work next day very easily and had a major puking just from 15min ride with oil level just above line when warm. took it back to dealer and they said they could not find anything only thing if I have a problem again would be to take heads apart and rebuild under warranty . I like my ride but this ain't right and down right embarrassing at work. I would never have bought it if I new this was going to happen on a brand new motorcycle. can some one tell me how I can complain to Harley Headquarters ?
Old 15th May 2015
DK Custom's Avatar
Why complain to HD headquarters? The dealer said if it happened again (and it probably will) they will rebuild under warranty. Probably you have one or two bad umbrella valves, and if they replace them, and anything else during the rebuild, seems like they are taking care of you.
Kevin
