Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Lubrication and Lubricants
Lubrication and Lubricants You guessed. Here is where everyone can argue over oil.
0 Carb starting issue.
Last Post: AudiloveS4
Last Post: bordens
0 80 xl1000 oil not circulating?
Last Post: smilinbrad
0 Wont Fire up!
Last Post: Mission1
0 Coil polarity
0 XR mutt race bike progress
0 show me your sporty next to an old or rural post office
Last Post: Hellbent_4
0 clutch issue
0 1998 883 spits and sputters at around 3000 rpm
Last Post: denguy
0 old style fender skirted
Last Post: Proteus
0 Warm/hot kickstart
0 Rubber mount gas tank part
Last Post: awright2009
0 Top end failure
0 Ebay ****evil knievel bike****
boblaine (85), mike wels (74), GaryR (64), cat5752 (53), Ocbuckeye (50), commandesc (45), vividblack05 (38), north_cack
chatter, engine noise, mobil 1, mobil one, synthetic
Old 30th August 2014
thesavageone33's Avatar
thesavageone33 thesavageone33 is offline
Sportster/Buell Model: XL883C
thesavageone33 is a splendid one to beholdthesavageone33 is a splendid one to beholdthesavageone33 is a splendid one to beholdthesavageone33 is a splendid one to beholdthesavageone33 is a splendid one to beholdthesavageone33 is a splendid one to beholdthesavageone33 is a splendid one to beholdthesavageone33 is a splendid one to beholdthesavageone33 is a splendid one to beholdthesavageone33 is a splendid one to beholdthesavageone33 is a splendid one to behold
Originally Posted by Ocgreenmachine View Post
Could it be a failing connecting rod on the crank? Is it coming low in the front jug?
Nah its more below the jugs, like the cases. But its more noisy everywhere. Could be though. Hard to tell, especiallynwith my loud ass exhaust
Savage
Originally Posted by shanneba View Post
What oil filter did you use?
Which Mobil1 oil did you use?
I have a wix motorcycle filter, not sure about the part #, but its what my bike calls for. And Mobil 1 v twin oil.
Savage
shotgun46's Avatar
the wrong Oil filter will also cause noise issues
Sportsters Rule ! :banana
Sleeper Sleeper is offline
Sportster/Buell Model: XL883R
Originally Posted by Mosey View Post
Find out what BushTec used and change the oil.
Yup, remove the variables and see if it comes back to what you had before.
^^Agree^^
Put everything back to the way it was before to eliminate it as the cause.
Dirty Old Dog
shanneba shanneba is offline
Savage
I wouldn't worry about it too much, it sounds like you may be getting more noise from the cam / lifter / pushrod area. I had more noise from there when using HD SYN 3. You have a good oil in there , ride till its time for another change. No need to waste the Mobil 1 oil, my 2 cents worth.
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
Ocgreenmachine's Avatar
Ocgreenmachine Ocgreenmachine is offline
Sportster/Buell Model: XB12Scg
Ocgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud of
I had noise from the front cylinder area (didn't have a chance to pinpoint where) which sounded like clattering after I changed from RevTech synthetic to royal purple... After which my #1 cam bushing seized and spun, causing catostrophic engine failure (bent pushrods/valves, etc). Root cause? Failing front connecting rod on my crank. The debris from the failing connecting rod got splashed up with the oil and caused the cam to seize.
2009 Buell XB12S w/Hammer Performance 1250 kit. Dean Adams RT-XB1 exhaust, Custom ECM.
The clattering was the connecting rod being loose and clattering.
Awesome!!
Sent from my DROID X2 using Tapatalk 2
Stocker's Avatar
Stocker Stocker is offline
Sportster/Buell Model: 883L (Well not really)
Other Motorcycle Model: A barn full of bikes
Stocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond repute
It had a little slack when releasing the clutch into first since I had bought it. Tightening the primary made a big difference. Travel is within spec, 1/4 to 3/8. Which ive since loosened back to what it was. Lot of guys on here claim to have noisy engines, but I hate it. And alot of them started after changing oil brands.
1/4 to 3/8's smokin' hot . Well not smokin' but hot. 3/8 to 1/2 cold. I lean towards the 1/2.
