Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Accessories
0 Top end failure
Last Post: Mission1
Last Post: fafcpa
0 Chinese S&S carbs
0 Main shaft bearing preferences
0 yost power tube guy
0 Lifters+w cams
Last Post: Gazotenekes
0 XR mutt race bike progress
0 Info needed on mini sumps.
0 Looking for an xlch engine
0 Keihin Butterfly crack
Last Post: Tipofthelake
0 Mystery transmission piece??
Last Post: Scott
0 Tire pressure
Last Post: BigMek
0 Gasket placement
0 What a birthday I've had
0 Adjustable main with mag
Last Post: davixlrtt
Last Post: mac93
0 Mounting seat with out frame tabs?
0 Cleaning carbon build-up
0 Changing Battery(with factory Alarm)
vt883, Danno, Otis_hd (70), Fisherman (69), New Girl (63), soup (58), motormyk (51), leo, UncleSmitty (43), bryguy1977
Old 23rd March 2008
Custom73 Custom73 is offline
Custom73 is an unknown quantity at this point
Default Trailer advice?
Not sure where to post this, so I'll try here...
I'm looking into getting a small flatbed trailer to haul my sporty and a friends bike. I'm not sure what is a good size to get. I've been looking at 4x7 and 5x8. They both have fold down ramp, mesh floor, and a 2000gvwr. What is a good size for two bikes and ample room to tie them down? What do you guys use or suggest? I appreciate any tips or ideas. Thanks.
Old 23rd March 2008
Rebil79's Avatar
Rebil79 Rebil79 is offline
Sportster/Buell Model: 1200
Rebil79 has much to be proud ofRebil79 has much to be proud ofRebil79 has much to be proud ofRebil79 has much to be proud ofRebil79 has much to be proud ofRebil79 has much to be proud ofRebil79 has much to be proud ofRebil79 has much to be proud ofRebil79 has much to be proud ofRebil79 has much to be proud ofRebil79 has much to be proud of
I have/use a snowmobile trailer. It a 2 place trailer 101" wide by 10' long. I have never hauled 2 bikes on it, but there would be plenty of room 2, maybe even a third one. Plus its a good size for anything else you might need to haul around. I orginally bought it for my snowmobile, but I have used it for a lot more things than that.
Rebil
Old 23rd March 2008
mid30's Avatar
mid30 mid30 is offline
Sportster/Buell Model: 1200r
mid30 is just really nicemid30 is just really nicemid30 is just really nicemid30 is just really nicemid30 is just really nicemid30 is just really nicemid30 is just really nicemid30 is just really nicemid30 is just really nicemid30 is just really nicemid30 is just really nice
Mine is 4x8 and I think it would be cramped trying to haul 2 on it. I would at least go with a 5' to 6' wide.
Old 23rd March 2008
d2dpaint d2dpaint is offline
Sportster/Buell Model: 883 hugger
d2dpaint is an unknown quantity at this point
Why Haul Ride Them
Old 23rd March 2008
Fourcats's Avatar
Fourcats Fourcats is offline
Sportster/Buell Model: XLCustom 883
Sportster/Buell Year: 99
Fourcats will become famous soon enoughFourcats will become famous soon enoughFourcats will become famous soon enoughFourcats will become famous soon enoughFourcats will become famous soon enoughFourcats will become famous soon enough
Rent a Uhaul 5x8 {covered}.
Old 23rd March 2008
Terp84Alum's Avatar
Terp84Alum Terp84Alum is offline
Sportster/Buell Model #2: Yamaha Raider
Sportster/Buell Year #2: 2010
Other Motorcycle Year: 2008
Terp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to behold
I have two trailers: a 4x8 that hauls my Sporty and a 6x12 that I used to haul my ATVs. There is no way that I could put more than one bike on my 4x8. 2 bikes would be no problem on the 6x12. The 5x8 may haul 2 if you stagger them but then length may be a problem. Also, the mesh floor will be a problem when it comes to tying down. Make sure you install eyelets with iron underneath.
Ken from Maryland
**RIP MR. JIMI & JOHNNY G**
Old 23rd March 2008
popeye_59's Avatar
popeye_59 popeye_59 is offline
Sportster/Buell Model: Sporster XL 883L
Sportster/Buell Model #2: E Glide Utra Classic
Sportster/Buell Year #2: 2002
popeye_59 is on a distinguished roadpopeye_59 is on a distinguished roadpopeye_59 is on a distinguished road
If you get a trailer get one with a wood floor. I hauled two bikes to sturges. and apparently every bump we hit the trailer floor flexed toward the center and the bikes were touching. I ended up with some scratches on my cam cover and a broken reflector on the engine guard of the other bike. there is not enough support in the floors on most trailers to support the weight of two bikes unless its a flooring made out of boards.
Old 23rd March 2008
Ok, thanks for the tips. I will look for a 5' or 6' wide bed. Thanks for noting the flexing steel floor - I'll definately look for wood.
Does it work to just tie it down to the flatbed against the front rail with ratchet straps - or do I need any special equipment to help hold it up and secure?
I'd rather ride them, but need to haul the kids to relatives on the way to Sturgis this year.
Old 24th March 2008
Phaedrus's Avatar
Phaedrus Phaedrus is offline
There are a number of wheel chocks you can buy.
Mine locks the front wheel in place so that I can load/unload and tie it down by myself.
Old 24th March 2008
Vegas1200C's Avatar
Vegas1200C Vegas1200C is offline
Vegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to all
If you do get a covered UHaul, don't tell them you will have bikes in it. They can't rent it if they think you have any gas powered engine inside.
Sold my 2004 Lava Red 1200 Custom, went darkside 2015 RGS
