Last Post: keithnh
0 Valve Lengths?
Last Post: motorhedmike
0 Chinese S&S carbs
Last Post: 11B40
Last Post: JonesL
0 73 XLH Total Power Loss
Last Post: sleighcrane
0 Cleaning carbon build-up
Last Post: commando57
0 Gasket placement
Last Post: Billy1200
0 XR mutt race bike progress
0 Info needed on mini sumps.
0 What oils do you run in your ironhead
0 Lifters+w cams
0 HF bike lift
Last Post: jharback
0 Chasing Down Leaks
Last Post: ericfreeman
vt883, Danno, Otis_hd (70), Fisherman (69), New Girl (63), soup (58), motormyk (51), leo, UncleSmitty (43), bryguy1977
2007, ecm, troubleshooting
Old 28th February 2015
Mightywarrior72 Mightywarrior72 is offline
Sportster/Buell Model: 883 Low
Mightywarrior72 is a jewel in the roughMightywarrior72 is a jewel in the roughMightywarrior72 is a jewel in the roughMightywarrior72 is a jewel in the roughMightywarrior72 is a jewel in the roughMightywarrior72 is a jewel in the roughMightywarrior72 is a jewel in the roughMightywarrior72 is a jewel in the roughMightywarrior72 is a jewel in the roughMightywarrior72 is a jewel in the roughMightywarrior72 is a jewel in the rough
Default 2007 sporty above 70mph
My wife rides 2007 sporty 883 (ECM model). Recently at speeds above 70mph she tells me that she lacks the power that she typically has. At 70 seems like max throttle is required. Nothing much above that. The symptoms seem to be periodic. On a couple of rides she has reported the issue, then a bit later symptoms are gone. It starts fine, idles nicely, sounds normal.
Where should my troubleshooting begin?
Intake leak? Should I check plugs for lean or rich condition? If so what do I look for on plugs? Should I check if plug wires are shorting to ground? If so what is the best way to check? Do the ECM bikes have vacuum lines? Could this be clogged fuel injectors? If so what should I run to help clean them out? She has only ridden a few times since the summer. Maybe a dozen times in 6 months. Could the injectors be clogging up with old gas?
Any help would be appreciated.
Thanks in advance.
sportsterdoc's Avatar
If compression checks good and spark is bright, I'd start with fuel flow
When is the last time that the two relays were replaced?
Sweet Terry Smoove's Avatar
Sweet Terry Smoove Sweet Terry Smoove is offline
Senior Bike Builder
Sweet Terry Smoove has a reputation beyond reputeSweet Terry Smoove has a reputation beyond reputeSweet Terry Smoove has a reputation beyond reputeSweet Terry Smoove has a reputation beyond reputeSweet Terry Smoove has a reputation beyond reputeSweet Terry Smoove has a reputation beyond reputeSweet Terry Smoove has a reputation beyond reputeSweet Terry Smoove has a reputation beyond reputeSweet Terry Smoove has a reputation beyond reputeSweet Terry Smoove has a reputation beyond reputeSweet Terry Smoove has a reputation beyond repute
Check for any stored codes.
I don't own a compression gauge, but with the help of some good brothers on this forum, we replaced both jugs last summer with some donated ones with about 30k on them. I will assume that they are good.
I replaced the two relays about two months ago. I had starter issues and I replaced the relays and put in new battery. One of those two solved the starting issue.
Regarding fuel flow, would it help to run sea-foam, fuel injector cleaner or something else through the injectors?
The times that she has reported the issue, it was cold outside and we were at the beginning of the ride. After warm up it seemed to get better. Does that help any with diagnosis?
I run enough WOT to not have fuel injector issues, so I cannot advise on FI cleaner
Does Wedge have a compression tester?
Mine's at my eldest son-in-laws in GA, where I am visiting. I could bring it home, but do not know when I will next go to SoCal.
Rethinking and with the added info posted, I'd go through electrical connections and check for codes as STS suggested
Senior Bike Builder
Also check to make sure that the throttle/return cables are adjusted correctly and are not binding. The throttle plate should open all of the way at full throttle
I checked;
P or the ECM None
S Turn signal None
SP Speedo None
T Tach No response (I don't have a tach)
I think this would indicate no ECM issues? What is it really checking for on the ECM code check? What can I rule out or in based on no error codes.
Thanks
Great Idea. I will check right now.
There seems to be a lot of slop on the cables at the throttle. The cables wiggle around quite a bit. Should I adjust the tension with the (Turnbuckles) where the cable attaches to the throttle at the handgrip? If so how tight should the cables be?
This is a F.I. bike. I don't know how to check for the throttle plate opening???
