Last Post: ronccc
0 Main shaft bearing preferences
Last Post: Heff
0 73 XLH Total Power Loss
Last Post: Tipofthelake
0 Chasing Down Leaks
0 Chinese S&S carbs
0 Tire pressure
0 K/n air filter,, and s/s super b long thumb screw bolts
0 Cutting Out Cracking Popping, Etc, After Fully Warmed Up
Last Post: Rgm883
0 XR mutt race bike progress
0 Hammer 1250 kit with fp3
Last Post: hexnut
Last Post: Magneto Sportster
0 Top end failure
Last Post: Mission1
Last Post: fafcpa
0 yost power tube guy
0 Lifters+w cams
Last Post: Gazotenekes
0 Info needed on mini sumps.
0 Looking for an xlch engine
0 Keihin Butterfly crack
0 Mystery transmission piece??
Last Post: Scott
0 Gasket placement
vt883, Danno, Otis_hd (70), Fisherman (69), New Girl (63), soup (58), motormyk (51), leo, UncleSmitty (43), bryguy1977
2007, ecm, troubleshooting
Old 1st March 2015
sportsterdoc's Avatar
Originally Posted by Mightywarrior72 View Post
Also I think I found the issue. Her throttle cables were extremely loose. The throttle body only opened up about 80 degrees instead of 90. This would probably account for about 90 percent of the power she said that she has. Also with all of the slop sometimes I could open it all the way, sometimes it would stick. I adjusted the cables at the jam nuts.
That explains a lot
Old 1st March 2015
Originally Posted by tyler.woodard04 View Post
Had to change my cables out due to being stretched. New ones let throttle open all the way. Going to keep new ones lubed better
I suspect that most throttle and clutch cables do not get the attention necessary for a long life
Old 1st March 2015
geekonabike's Avatar
geekonabike geekonabike is offline
Sportster/Buell Model: XL883 Sportster
geekonabike has a reputation beyond reputegeekonabike has a reputation beyond reputegeekonabike has a reputation beyond reputegeekonabike has a reputation beyond reputegeekonabike has a reputation beyond reputegeekonabike has a reputation beyond reputegeekonabike has a reputation beyond reputegeekonabike has a reputation beyond reputegeekonabike has a reputation beyond reputegeekonabike has a reputation beyond reputegeekonabike has a reputation beyond repute
It sounds like you solved it: throttle cable not opening it up enough. That said, what probably made her notice it was what you said earlier, that it was cold and the bike wasn't fully warmed up. When I first got mine I noticed if I took it out and hit this one north-south highway there were times it seemed pretty lethargic when riding into the wind, if it were blowing 20+ mph, which it often does out here in SW Oklahoma. Usually I jump on the 70 mph east-west highway instead, and don't have any issues.
Once fully warmed the bike (2006 883, mostly stock) definitely has more punch.
Thanks for posting. I might just have a look at my throttle cables.
Old 1st March 2015
Mightywarrior72 Mightywarrior72 is offline
Sportster/Buell Model: 883 Low
Mightywarrior72 is a jewel in the roughMightywarrior72 is a jewel in the roughMightywarrior72 is a jewel in the roughMightywarrior72 is a jewel in the roughMightywarrior72 is a jewel in the roughMightywarrior72 is a jewel in the roughMightywarrior72 is a jewel in the roughMightywarrior72 is a jewel in the roughMightywarrior72 is a jewel in the roughMightywarrior72 is a jewel in the roughMightywarrior72 is a jewel in the rough
You know where Jester Motorwerkz is right ?
I do indeed. And I do appreciate your help. I'm trying to do this one on my own. But I do know where to go if I fail.
Thanks
Old 2nd March 2015
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
remove the air cleaner and look at the throttle plate to see if it goes fully horizontal.
fuel flow and rpm is controlled by the Throttle Position Sensor TPS. Tells the computer what the motor is looking for.
