12 Crankcase breathing?
0 Do you use a bike cover?
Last Post: Old Rocker
0 Rear sets?
Last Post: bordens
Last Post: Vic8028
0 Sportster Fork Upgrade
Last Post: PetesPonies
0 "S" model specific Q&A
0 Ground Up Beginner Build
Last Post: Paul.W
0 Turbo Iron 883
Last Post: Cj_
Last Post: Blackmagellan
0 Clutch springs
Last Post: BigMek
0 Coil polarity
Last Post: Bikeaholic
0 Info needed on mini sumps.
0 primary cover
Last Post: smoggy
Last Post: davesz1r
0 Chinese S&S carbs
0 oil transfer valve
0 Tappet blocks and tappets
PEISprotster (68), 2009XR (66), Briank (61), bbj6635 (59), Reddog225 (48), larre1973, Irondrake77 (41), picowatt (40), Jeffrey99 (39), namesnick (39)
brake caliper, brake lever, disc brakes, sportster 1200
Old 21st November 2017
Sportster-92 Sportster-92 is offline
Sportster/Buell Model: sportster XLH 1200
Sportster/Buell Year: 92
Sportster-92 will become famous soon enoughSportster-92 will become famous soon enoughSportster-92 will become famous soon enoughSportster-92 will become famous soon enoughSportster-92 will become famous soon enoughSportster-92 will become famous soon enoughSportster-92 will become famous soon enough
Default Front brake single piston problem
Hey guys I have been having this really annoying issue with my front single piston floating calliper brake system on my 92 sportster where the brakes drag hard. I get a 1/2 turn if lucky and get constant high pitch noise when riding the bike all the time. I also have too much play up at the lever.
I drained the system, pushed out the piston and cleaned out the whole calliper. noticed a few light marking on one side of the piston but nothing major and there was no scoring. The seal looked good inside so left in.
Fitted a rebuild kit to the master cylinder and before filling up with dot 5 the lever play had completely gone. So the spring must be pushing the lever back correctly. After filling and bleeding it was just as before with the brakes hard on and the same amount of lever play.
Its driving me crazy now.
Any suggestions would be great.
Cheers.
hotrodbiker hotrodbiker is offline
Sportster/Buell Model: xl 883/1200
Sportster/Buell Year: 91
Other Motorcycle Model: ducati triumph enfield
hotrodbiker is an unknown quantity at this point
Hi again ! I ve never had this occur on a bike but if you ve got the original rubber brake hose they can break down inside and allow fluid to put your brake on but not return ,just a thought , I have had this happen to my old Jeep and new lines fixed it
hope this helps
Cheers Hotrodbiker its actually got a stainless hose thats not that old by the look of it.
ahhh wont be that then ..damn ! Hopefully someone else can help you out , I cant think of anything that would cause drag and a sloppy lever ...with the brake dragging so much do you think it may have heated the disc and warped it ?
juzyHD's Avatar
juzyHD juzyHD is offline
Master Bike Builder
Sportster/Buell Year: 1986
What about the other side of the caliper? Does it moves freely?
I doubt the disc is warped but will check it out when I strip the mag wheels when I convert to the spoked. It looks like I am going to have to replace the piston and seal on the calliper. It didn't look to bad, its the only thing that I can think of that might affect the system. Its like the pistons won't return back in after the lever has been released.
Hi JuzyHD its a 92 calliper so it only has a piston on the one side.
Cheers.
just realised I haven't mentioned its a single disc brake
juzyHD's Avatar
Master Bike Builder
Yes there is piston only on one side, but the other part should move freely. Otherwise you only get pressure on the left side of the disc. The part of the caliper that goes over the disc to the right side must move freely on the bolts. The housing of the caliper or how should I say...
Thanks for the info Juzy the calliper does float correctly as I checked this and greased the bushing and mount pin. Its seems like the piston is pushing on the disc and sliding the calliper over as both pads are on the disc. Resulting in 1/2 a turn of the wheel by spinning it by hand and the lever does not return fully.
Cheers.
