0 Coil polarity
Last Post: Medyo Bastos
0 Top end failure
0 Difference in Clutch Levers 45356-07 vs kit 44992-07
Last Post: The Doctor71
0 1998 883 spits and sputters at around 3000 rpm
Last Post: Tommr
0 Ground Up Beginner Build
0 clutch issue
Last Post: zack2267
Last Post: Billy1200
0 HD Museum Video - 1968 IH Dragster by Tom Reiser
Last Post: thefrenchowl
Last Post: Pagey
0 Valve keepers won't come out
Last Post: LLOYD883
0 Turtle tank on '79 frame
0 Chinese S&S carbs
0 Sportster Fork Upgrade
Last Post: PetesPonies
0 2009 883
0 "S" model specific Q&A
0 old style fender skirted
0 What's your road name? How did you get it.
1973, brake, caliper, ironhead, stuck
Old 20th November 2018
jtnelson89 jtnelson89 is offline
Sportster/Buell Model: XL1000
Sportster/Buell Year: 1973
Sportster/Buell Model #2: XLH883/1200
Sportster/Buell Year #2: 1998
Other Motorcycle Model: too many to list
jtnelson89 is an unknown quantity at this point
Unhappy 1973 XLH1000 stuck front brake caliper
Hi guys,
This is one of the first things I'm doing to my new project.
I pulled the front brake caliper and used compressed air to try and force the piston out of the caliper. Even at well over 100 PSI, all I got was a whole bunch of brake fluid in my face.
So then I turned it away and tried again, and still no dice. That caliper is stuck.
Any advice, tips or tricks?
Jeff
1973 XLH1000
Smile the old "hit it with a hammer" ploy
Well, I was able to solve the problem using the old "hit it with a hammer until it moves" ploy. Just some tapping on the caliper piston loosened it up, and then the air at 100PSI moved it back. I had to hit it back in again, and then it came out with more air.
It was the same with the piston inside the master cylinder. First I had to remove a snap ring. Then I was able to force the piston backwards using a punch and a hammer. The air moved it. A little back and forth with hammer and then air finally removed the piston.
Here's a link to the photos: https://photos.app.goo.gl/6CjaUbie1qKJczmw6
What do you think: Do any of these parts look to bad to reuse? I am pretty sure I need to replace the caliper piston, as it has some scoring and little ridges, and certainly the master cylinder piston as well. I'm most concerned about the master cylinder, as I haven't cleaned it up well enough to tell the story yet.
What do you think: What's the best stuff to use to clean this out? Brake cleaner? Gas? A bit of light scuffing with emery cloth wrapped around a dowel? Something else?
ChinCactus's Avatar
Looks pretty crusty. I think it it were mine I'd look for replacements. Don't want to chance brakes.
harley506d's Avatar
Sportster/Buell Model: 1200c
All you can do is clean it and replace what you think is bad and try it. Nothing to lose.
But as ChinCactus say's, look out for better replacements, they do look bad.
Sadsack's Avatar
Sadsack Sadsack is offline
Sportster/Buell Model: Xlh
Sportster/Buell Model #2: FX
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 2014
Sadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud of
Block off the the brake line and screw a grease fitting into the bleeder hole...grease gun has a lot more pressure than an air compressor. Never fails!
I've often run with the devil, but I've never made any deals....
Default thanks
Thanks Sadsack for the advice to use a grease gun! I'll try that next time.
You can get a new piston for the caliper, but the master cylinder is probably a write off.
Old 21st November 2018
Default new parts coming
Guys, based on your advice and after looking at the cost of the parts, I have decided it will be safer and more cost-effective just to get a new caliper and new master cylinder housing. I found what I needed from Ebay, Dennis Kirk, and JPcycles, and should have everything within a couple of weeks.
