0 Valve Lengths?
0 73 XLH Total Power Loss
Last Post: Erikdowney18
0 Cleaning carbon build-up
Last Post: vt883
Last Post: commando57
0 Gasket placement
Last Post: Billy1200
0 XR mutt race bike progress
0 Info needed on mini sumps.
0 What oils do you run in your ironhead
0 Lifters+w cams
Last Post: supermotolew
0 HF bike lift
Last Post: salmanmr
Last Post: jharback
0 Chasing Down Leaks
Last Post: ericfreeman
0 Main shaft bearing preferences
Last Post: Heff
0 Chinese S&S carbs
0 Tire pressure
0 K/n air filter,, and s/s super b long thumb screw bolts
vt883, Danno, Otis_hd (70), Fisherman (69), New Girl (63), soup (58), motormyk (51), leo, UncleSmitty (43), bryguy1977
ironhead 1979, pinion gear
Old 30th January 2019
JSH JSH is offline
Sportster/Buell Year: 1979
JSH is an unknown quantity at this point
Default Excellent. Thank you. Now we are getting somewhere
Okay, no timing on the oil pump - I wondered if that might be the case, but figured it must have some sort of vent window that should be timed to the crankcase.
Timing off the front cylinder - I figured that, too, but when this cam case is set up correctly and the flywheels set with the line in the timing hole (front cylinder at 40 degrees BTDC, and rear cylinder exactly at TDC, also the crankpin is showing in the #2 cam hole), the breaker points cam lobe ends up with it's wide rear cylinder lobe pointing to the right at 3 o'clock, about to break the points, rather than the narrow lobe for the front cylinder. There is only one correct way to install that points plate, so what is going on here?
I would love to post y'all some pictures of the whole thing here, but the page won't let me do it I have some great pics. How do I post them?
Toejam503's Avatar
Sportster/Buell Year #2: 1981
imgur.com or imgbb.com. Both sites are free.
https://postimg.org/ is another. Whichever you choose Copy/Paste the IMG code from there to your post here.
Best to avoid PhotoBucket
iNSaNeSHaNe's Avatar
Sportster/Buell Year: 1985
I'm trying to go by memory so don't assume i'm correct but ..
If I remember correctly when setting the cams in and all of the marks are lined up the front cylinder is on the overlap 180° out of compression which would explain your issue. My suggestion is roll the engine over and watch the lifters to make sure the intake has just closed coming up on compression then TDC . Then you are in fact timing on the correct stroke and on compression not the overlap.
Sportster/Buell Year: 1971
Sportster/Buell Model #2: xlh
Other Motorcycle Year: 2011
Here's a mini step by step on how to post pics from Flickr -->
http://xlforum.net/forums/showpost.p...42&postcount=6
never say never, seen the mechanism installed incorrectly and also the points backing plate installed wrong, pics are great.
Old 31st January 2019
JSH JSH is offline
Default Here are the pictures!
and sorry for the delay. You should see all of the photos at this URL.
https://www.flickr.com/gp/167943728@N03/f06tB8
chevelle's Avatar
chevelle chevelle is offline
Sportster/Buell Year: 19**
Sportster/Buell Year #2: 1965
Again,
Rotate engine until slash is in window.
Front cyl must be on compression stroke, tappets down!
If all the keys, all the roll pins are there and all the marks line up including the pinion gear to shaft marks then it HAS TO BE RIGHT.
Your pictures show everything correct but it's not on the compression stroke. For the ignition timing rotate the crankshaft one more turn, put the flywheel mark in the hole and the narrow lobe will be facing the points like it should be.
When you're on the right stroke the notch on #2 cam points to about 11 o'clock with the mark in the timing hole. Like in the left side of this picture.
http://xlforum.net/forums/showpost.p...8&postcount=14
You continue to reference the flywheel position as it relates to the cam timing. You shouldn't be doing that. The mark on the pinion gear is doing that for you. So forget flywheel and piston position. Just put the cams in with all the marks aligned.
One of your pictures is Labeled: "crankpin viewed through #2 cam bearing hole at 40 degress BTDC on compression stroke." Again, it doesn't matter where it is, but how can that even be? There are no cams installed to establish where the compression stroke is.
In another thread you rightly figure that the pinion gear being installed 2 splines off on a six spline shaft is a 120° error. That would be 120 crankshaft degrees because the pinion turns the same as the crank. It would be 60° at the cams.
It's possible that has created another problem for you because the engine was rotated like that.
When the cam timing is correct with stock cams the intake valve opens to just over half its total lift when the piston is at TDC. By starting it's opening 120° early the valve would go to full lift at TDC. So if the valve was supposed to open at 35° BTDC it would then start to open at 155° BTDC. If there isn't plenty of piston to valve clearance the piston could hit and bend the valve.
I'm not saying it did, but if you get the cam case sorted out and the engine runs like crap that may be an issue. A compression test may be needed.
Good luck.
Old 1st February 2019
JSH JSH is offline
Default Thank you!
That was the best and most professional answer I have seen
You da man
