0 Valve Lengths?
0 73 XLH Total Power Loss
Last Post: Erikdowney18
0 Cleaning carbon build-up
Last Post: vt883
Last Post: commando57
0 Gasket placement
Last Post: Billy1200
0 XR mutt race bike progress
0 Info needed on mini sumps.
0 What oils do you run in your ironhead
0 Lifters+w cams
Last Post: supermotolew
0 HF bike lift
Last Post: salmanmr
Last Post: jharback
0 Chasing Down Leaks
Last Post: ericfreeman
0 Main shaft bearing preferences
Last Post: Heff
0 Chinese S&S carbs
0 Tire pressure
0 K/n air filter,, and s/s super b long thumb screw bolts
vt883, Danno, Otis_hd (70), Fisherman (69), New Girl (63), soup (58), motormyk (51), leo, UncleSmitty (43), bryguy1977
ironhead 1979, pinion gear
Old 7th February 2019
JSH JSH is offline
Sportster/Buell Year: 1979
JSH is an unknown quantity at this point
Hey all,
I want to thank you for your help and suggestions. The Sporty lives again!
The pinion gear was indeed out of place on the shaft. I still have no idea how it was running before it came to me, but not wee I expect. Besides that, the fix was: get some sleep, think about it, pull it all back apart and do things like I knew should be done and as y'all suggested, and voila'... everything lined up almost perfectly. I say 'almost' because the points breaker plate hd to be adjusted all the way left (advanced) to max adjustment in order to get the points to break correctly in advance position. I have never seen one needing that extreme of an adjustment. I set the carb and valves, then pushed the button. It coughed for one second and then ran perfectly. The nicest, gentlest idle lope and perfect acceleration - not a hiccup.
I recommend this and my previous thread for anyone having similar problems. It sure helped me.
Oh, and the reason I started this second thread ("Ironhead timing troubles,"for those of you who asked) is because I am a newbie dunderhead who didn't know how to find his original thread.
Thanks again...
Yellowstone Kelly's Avatar
Ironhead Rider
Sportster/Buell Year: 1982
Sportster/Buell Year #2: 1969
Other Motorcycle Model: FLSTC
Other Motorcycle Year: 1996
Yellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant future
JSH,
Thanks for taking the time to come back in and let us know what you had to do to get it running!
