0 What a birthday I've had
0 Tire pressure
0 Chinese S&S carbs
Last Post: sleighcrane
0 Adjustable main with mag
Last Post: davixlrtt
Last Post: mac93
0 Mounting seat with out frame tabs?
0 Cleaning carbon build-up
0 Changing Battery(with factory Alarm)
0 Gasket placement
Last Post: Billy1200
0 Top end failure
Last Post: Mission1
0 Mystery transmission piece??
0 Keihin Butterfly crack
Last Post: Tipofthelake
0 XR mutt race bike progress
Last Post: supermotolew
0 Info needed on mini sumps.
Last Post: mrmom9r
0 Don't Think I Ever Did This
Last Post: Veeflys
0 Hammer 1250 kit with fp3
Last Post: Pagey
0 Sticky Ironhead trans
0 Inherited Ironhead
0 HF bike lift
Last Post: BigLerowski
0 Graduated to Ironhead
bobber, chopper, front brake, ironhead 1980, rigid ironhead
Old 4th July 2019
Bigshankhank Bigshankhank is offline
Sportster/Buell Model: Ironhead Hardtail
Other Motorcycle Model: KTM Duke 390
Other Motorcycle Year: 2015
Bigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant future
Officially had my first break down on my very first ride today, so that's out of the way. Lost the bolt holding the cables to the negative battery terminal. Noticed it when I stopped for gas, but was able to start the bike by holding the cable to the terminal while turning the key, then limped home so I didn't lose the battery charge. Good times.
Old 5th July 2019
So a little red loctite on both battery bolts and we are back in business.
Old 23rd July 2019
Started lining up and ordering parts for the front brake. I ordered fork lowers and will grind off the fender brackets, as well as a left caliper and a new seal kit. Next up will be some lower and narrower handlebars and a master cylinder brake lever, then get a new braided brake line. Oh yeah and will need a new disc, also. I'll gather the parts a few at a time because I am a masochist.
Old 27th July 2019
Highly-Dangerous's Avatar
Highly-Dangerous Highly-Dangerous is online now
SPANIARD
Red? that´s a bit overkill IMO. I use Blue and never got loose.
CLICK->>"Maintenance is as much art as it is science"<<-CLICK
Old 28th July 2019
Boil1337 Boil1337 is offline
Slackmaster
Sportster/Buell Model: XL883L
Boil1337 is just really niceBoil1337 is just really niceBoil1337 is just really niceBoil1337 is just really niceBoil1337 is just really niceBoil1337 is just really niceBoil1337 is just really niceBoil1337 is just really niceBoil1337 is just really niceBoil1337 is just really niceBoil1337 is just really nice
Meet in the middle with some purple loctite (the preferred loctite of Sam Jackson)...?
Old 28th July 2019
SPANIARD
LMAO
Old 30th July 2019
Red is what I had in the toolbox. Considering how infrequently I (should) be having to replace the battery, I am good with a solid connection there.
Old 9th September 2019
New set of bars from TC Bros, pretty happy with how they fit.
Old 24th September 2019
Finally sorted out the parts I need for the front brake, but first I need to shave a few unnecessary bits off of the new fork leg, seeing as a proper bobber doesn't have a front fender.
Step 1, chuck it up in a vice and let's get to work. FWIW I bought this fork on ebay and got it cheap because the tube was bent, so I don't care about cranking down on it with the vice.
Cut the mount off of the non-brake side first
The switch over to the brake side since it involved a few extra cuts
End result of the cutting stage, pretty clean.
Last but not least, start sanding. This was an 80 grit disc which was too fine but its what I had in my toolbag when I started and I didn't want to go too aggressive at first. I have since gotten a 40 grit and will knock it down some more before going back to the 80. Even with the 80, it still made pretty good work of it. Once the tool work is done, I'll wrap it with some 220 and 400 paper and smooth it down then paint and ready for installation.
Old 15th October 2019
Any thoughts on draining the oil? I ask because there is no drain plug on the oil tank itself, and from reading the technical stickies on here draining from the sump is pointless and risky. Best I can come up with is to siphon the old oil out through the tank filler neck. Only problem is the tank cap has no dipstick, so refilling it is flying blind.
