8 Inexplicable miss
5 Eye Protection When Riding?
0 Ignition advice
0 Chinese S&S carbs
0 normal shifter shaft wobble
0 Bandanas
0 Top end failure
Last Post: Mission1
0 XR mutt race bike progress
Last Post: Scott
0 1992 XL ignition explained
Last Post: Bwf347
0 New guy from IL
0 Front Brake Upgrade
Last Post: keithnh
0 Info needed on mini sumps.
Last Post: Randy_rots
0 Coil readings
Last Post: Billy1200
0 3/4” Axle Drum Brake ??
0 Inherited Ironhead
Last Post: Akdawg
0 Noise and rod play
Last Post: Vic8028
Old 1st March 2020
sml1226 sml1226 is offline
I don’t think I have my old instructions to see what they said. Now you’ve got me wondering if I just ignored them or if they’ve changed since I installed mine.
Old 1st March 2020
rejeanprimeau's Avatar
Either way is good, as long as your friction side in toward the pressure plate who care.
What not to do is steel side to pressure plate or bottom of the basket.
Mechanically, it will spin like a burnt clutch if you go steel on metal (pressure plate or basket back plate). I don't see any advantage for the clutch were the friction side are.
On the OEM the friction is on both side with double sided steel.
Now the XR judder spring can be installed easily.
Old 1st March 2020
rocketmangb's Avatar
I dont see the point in it.
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 1st March 2020
Bluto Bluto is offline
Other Motorcycle Model: Norton 850 Commando
Other Motorcycle Year: 1973
If you have a squeal from the clutch when taking off in first gear the XR1200/Buell XB judder spring setup will likely eliminate it (this is assuming no spring plate) plus it can make clutch take up smoother and less abrupt...but if you don't have a squeal and are happy with the clutch feel then no point.
FWIW Barnett used to supply a very similar 1/2 width plate and judder spring with their Sportster clutch kits.
Old 1st March 2020
It definitely doesn’t matter if you go one direction or the other with the Carbonite stack provided relative orientations are good, this just made me curious whether I’d done it “backwards” the whole time or not.
I’m curious what the cost difference would be for HD to actually change it and just use the XR setup as the factory assembly. It makes so much more sense to have an extra friction plate double as your damper than run a squishy triple wide drive plate in there, especially when it’s known to fail catastrophically.
Of course, running a solid stack works for a lot of people without issue, and that’s cheaper than swapping to the superior (to stock) damper assembly. Like everyone’s said, if it doesn’t squeal, run it straight. If it does, the XR parts work great, even with the Carbonite.
Old 1st March 2020
Hippysmack's Avatar
Hippysmack Hippysmack is online now
Rocketman, can you post the instructions?
Old 1st March 2020
https://www.motorcycleid.com/images/...structions.pdf
Old 1st March 2020
Thank You !
Old 1st March 2020
FWIW when I installed the XR1200 judder spring a year ago in place of the spring plate and got rid of the squeal I had with the two steel/one friction spring plate replacement deal I sent an email to HD's customer suggestion box...but got no reply. Agree, the change from spring plate to judder spring on XL's could be done at the factory at little or no cost.
(I doubt I'm the first to think of the XR1200/Buell XB judder spring fix however didn't see another reference on the web last year...but did get the idea from the Barnett diagram above)
Old 2nd March 2020
oldboy's Avatar
oldboy oldboy is offline
Other Motorcycle Model: Ducati
Other Motorcycle Year: 1974
oldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond repute
My buddies 2003 Softail had the judder spring setup from the factory. The parts are called a damper spring seat and diaphragm spring. I didn't cross check to see if they are the same part numbers as the XR parts.
2006 1200c: Home Made a/c, Cycle Shack Slipons, Daytona TC88A w/JesterVII map (thank you, Rico), Street Trackers
