0 XR mutt race bike progress
Last Post: Hellbent_4
0 show me your sporty next to an old or rural post office
0 clutch issue
0 Wont Fire up!
Last Post: Mission1
0 1998 883 spits and sputters at around 3000 rpm
Last Post: denguy
0 old style fender skirted
Last Post: Proteus
0 Warm/hot kickstart
0 Rubber mount gas tank part
Last Post: awright2009
0 Top end failure
0 Ebay ****evil knievel bike****
Last Post: gusm2
0 "S" model specific Q&A
0 N65C or N65A
Last Post: lespaul6
0 Coil polarity
Last Post: davesz1r
Gold951 (69), tujbob (65), tcspannerwrench (54), rondog (51), scootsgal (49), barney27 (46)
engine noise, valves
Old 31st July 2009
cadgenyus cadgenyus is offline
Sportster/Buell Year: 09
cadgenyus is an unknown quantity at this point
Default 09 Nightster Valve Rattle??
A little help here.....
This is my first street bike. I bought it in May 09 with 7 miles on it. As of yesterday, I just tripped 3,000 miles. I have performed the 1,000 recommended maintenance...but I did it at 2,000 miles (miscommunication between the salesman and me)
Yesterday while I was riding, I noticed a "Rattle-Rattle-Rattle" from the LEFT side of the bike when I hit the throttle.
I had never heard this type of rattle before. It sounded VERY similar to a car when the valves rattle.
It only happened when I had RPM's on the engine....around 2-3k RPM.....and then I hit the throttle.
So basically, I'm cruising along at 2-3k RPM.....hit the throttle...and right at the beginning of the ramp up on the engine rpm....it would make the "Rattle-Rattle-Rattle" (similar to the car valve rattle sound) from the LEFT side of the bike and then go away immediately.
Now, yes...the bike is under warranty and I could run it to the dealership and drop it off so that they could look at it. However, if I could post here and save me that long trip and inconvenience....I would deeply appreciate that.
Yesterday's conditions:
The engine had been running for awhile. Yesterday was the hottest day that I've run the bike. 86 and humid.
Any ideas? Is this "normal"?
I hope what I've explained makes sense.
Old 31st July 2009
linkin5's Avatar
linkin5 linkin5 is offline
Other Motorcycle Model: Honda XL 125
Other Motorcycle Year: 1982
linkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nice
Pre-detonation?, what octane are you running, I use 92 and have very little.
Old 31st July 2009
bigjnsa's Avatar
bigjnsa bigjnsa is offline
Sportster/Buell Model: XL 883
Other Motorcycle Model: BMW R1150R
bigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to all
Sounds like you're using the wrong octane.
aka - 'Bubba' of the Hells Beerguts MC
When we ask for advice, we are usually looking for an accomplice.
Marquis de la Grange (1639 - 1692)
[SIGPIC][/SIGPIC]
Old 31st July 2009
I only run 92 octane and I try to only buy my gas from "brand name" gas stations.....ie Mobil/Irving/Shell
Granted....this could be a bad batch of gas...don't know.
Old 31st July 2009
colonelangus's Avatar
colonelangus colonelangus is offline
colonelangus is just really nicecolonelangus is just really nicecolonelangus is just really nicecolonelangus is just really nicecolonelangus is just really nicecolonelangus is just really nicecolonelangus is just really nicecolonelangus is just really nicecolonelangus is just really nicecolonelangus is just really nicecolonelangus is just really nice
untill its fully broken in keep the rpm's up NO lugging,and use high octane fuel.i use chevron 94 only
Old 1st August 2009
Shaft's Avatar
Shaft Shaft is offline
Shaft is a jewel in the roughShaft is a jewel in the roughShaft is a jewel in the roughShaft is a jewel in the roughShaft is a jewel in the roughShaft is a jewel in the roughShaft is a jewel in the roughShaft is a jewel in the roughShaft is a jewel in the roughShaft is a jewel in the roughShaft is a jewel in the rough
This may be a long shot, but it's simple enough to check... make sure the gas cap is on tight. Seems loose caps can make some noises that sound more alarming than it really is.
Old 1st August 2009
Nightster Man's Avatar
Nightster Man Nightster Man is offline
Nightster Man will become famous soon enoughNightster Man will become famous soon enoughNightster Man will become famous soon enoughNightster Man will become famous soon enoughNightster Man will become famous soon enoughNightster Man will become famous soon enough
Sometimes you can get bad gas. I wouldn't worry too much. Run through the gas in your tank and fill up again with at least 92 octane, see what happens.
2008 XL1200N, Vivid Silver/Black Denim, Rush Mufflers w/ 2" Baffles, Willie G. Skull Covers, Black Pivot Bolt & Axle Covers. Lick's Solo Bag. More to Come.
Old 1st August 2009
danonator's Avatar
danonator danonator is offline
danonator is on a distinguished roaddanonator is on a distinguished roaddanonator is on a distinguished roaddanonator is on a distinguished roaddanonator is on a distinguished road
Like Shaft said.. check for rattles from gas cap etc.
Try mixing in some AVGAS (aviation fuel) if you have a supplier near you and then run it. AVGAS has a high octane and will not deteriorate like regular gas will.
Let us know what you find.
Danonator
Old 1st August 2009
Hogwylde's Avatar
Hogwylde Hogwylde is offline
Sportster/Buell Model: 883-1200 Custom
Hogwylde has a reputation beyond reputeHogwylde has a reputation beyond reputeHogwylde has a reputation beyond reputeHogwylde has a reputation beyond reputeHogwylde has a reputation beyond reputeHogwylde has a reputation beyond reputeHogwylde has a reputation beyond reputeHogwylde has a reputation beyond reputeHogwylde has a reputation beyond reputeHogwylde has a reputation beyond reputeHogwylde has a reputation beyond repute
You can always put some NOS in it....
http://www.gixxer.com/forums/showthread.php?t=226570
I am only joking here. DO NOT do what this guy did!
The mind is like a parachute. Works best when open.
Old 1st August 2009
Fackler Rebel's Avatar
Fackler Rebel Fackler Rebel is offline
Sportster/Buell Model: XL1200 Standard
Fackler Rebel has a spectacular aura aboutFackler Rebel has a spectacular aura aboutFackler Rebel has a spectacular aura aboutFackler Rebel has a spectacular aura aboutFackler Rebel has a spectacular aura aboutFackler Rebel has a spectacular aura aboutFackler Rebel has a spectacular aura aboutFackler Rebel has a spectacular aura aboutFackler Rebel has a spectacular aura aboutFackler Rebel has a spectacular aura aboutFackler Rebel has a spectacular aura about
You're hearing pinging, not rattling. My 2000 did that when I ran under 3000 rpm in 5th when I first had her. I did a 1500 mile trip, drove the heck out of her and it stopped? Still not good to lug your bike. Since your's is a 2009 it came from the factory on the lean side, so it's prone to do that. Just keep your rpm up and it will go away.
Reb
2000 Xl1200 V&H straightshots, SE aircleaner, highway pegs, deluxe seat, sissy bar, luggage racks, saddle bags, and QD windshield. Made to be comfortable while I haul ass. Black and chrome. Man is she pretty.
Back Home in Alabama - How sweet it is!
