Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > REGIONAL FORUMS > Australia - The Land of OZ
Here is where you can post about anything in Australia. Events, Where to eat, Where to get help, Dealers, Indys, etc....
Last Post: bordens
0 Carb starting issue.
Last Post: Billy1200
0 Be Careful Out There!
0 clutch issue
0 Mikuni Knock Off "REVEALED" !!!
Last Post: davesz1r
0 Ebay ****evil knievel bike****
Last Post: MnKevin
0 Coil polarity
0 Chinese S&S carbs
Last Post: T. Clark
Last Post: bordens
0 80 xl1000 oil not circulating?
Last Post: smilinbrad
0 Wont Fire up!
Last Post: Mission1
0 XR mutt race bike progress
0 show me your sporty next to an old or rural post office
Last Post: Hellbent_4
0 1998 883 spits and sputters at around 3000 rpm
Last Post: denguy
0 old style fender skirted
Last Post: Proteus
boblaine (85), mike wels (74), GaryR (64), cat5752 (53), Ocbuckeye (50), commandesc (45), vividblack05 (38), north_cack
Old 17th January 2007
sycle1's Avatar
sycle1 sycle1 is offline
sycle1 has a spectacular aura aboutsycle1 has a spectacular aura aboutsycle1 has a spectacular aura aboutsycle1 has a spectacular aura aboutsycle1 has a spectacular aura aboutsycle1 has a spectacular aura aboutsycle1 has a spectacular aura aboutsycle1 has a spectacular aura aboutsycle1 has a spectacular aura aboutsycle1 has a spectacular aura about
Doh got it.
Faaa ark what a dunce.
Gold Coast Australia
2001 XLH now with add ons & more bug guts.
With some diamond encrusted tweezers in my hand, me and the pigmy pony over by the dental floss bush.
Old 2nd June 2007
davidcar's Avatar
davidcar davidcar is offline
davidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura about
Trust me to find this thread after starting a new one. I will remove the other and add my comments here.
MOVED FROM THREAD "PENRITE HPR GAS 20W60 is very good"
I have started using Penrite HPR GAS 20w60 engine oil and have to say that it is very good. In the past when it was available I used Pennzoil multi-viz and that was a good oil for Harley's but it is not anymore because they changed the formula. I have tried various other oils and non could perform as good as the Pennzoil until I started using the Penrite HPR GAS 20w60, I highly recommend it . Also for primary oil Valvoline HP80w90 is very good
1200 XLH, "D" shaped exhaust port, SE 497 cams, 9.5:1 CR, 1.850 inlet & 1.615 exhaust valve, 48 primary & 190 main jet, NOKK needle no shim. 84TQ & 81HP
Last edited by davidcar; 2nd June 2007 at 10:47.. Reason: stuffed up and started new thread on oil
Old 2nd June 2007
Horace18 Horace18 is offline
Loose Nut
Sportster/Buell Model #2: XLCR
Sportster/Buell Year #2: 1978
Other Motorcycle Model: FLHTK
Other Motorcycle Year: 2014
Horace18 is a jewel in the roughHorace18 is a jewel in the roughHorace18 is a jewel in the roughHorace18 is a jewel in the roughHorace18 is a jewel in the roughHorace18 is a jewel in the roughHorace18 is a jewel in the roughHorace18 is a jewel in the roughHorace18 is a jewel in the roughHorace18 is a jewel in the roughHorace18 is a jewel in the rough
I put Syn3 in the engine and trans on the first oil change, was quieter than the original oil. Then went to Mobil 1 second change in engine only, quieter still. Back to Syn3 now due to availability of Mobil 1 up North, though am about to put Mobil 1 back in engine and trans. Mobil 1 VTwin that is. Bike mostly does short runs to work (3km) with the odd long ride and drags in between. Have done 22,000km with no known side effects thus far, despite temps in high 40's through the wet season.
Old 2nd June 2007
sycle1's Avatar
I use the Syn 3 also in engine and trans.
Done 10,000 using it no hints of a problem here.
Except its too expensive may switch too Mobil one or Castrol synthetic in the future.
Old 9th March 2008
mortgarson mortgarson is offline
mortgarson will become famous soon enoughmortgarson will become famous soon enoughmortgarson will become famous soon enoughmortgarson will become famous soon enoughmortgarson will become famous soon enoughmortgarson will become famous soon enough
Is penrite hpr stator safe (yellow metal)
Cheers Mtr Glenn
Old 10th March 2008
davidcar's Avatar
yes, it is safe
Cheers Mtr Glenn
Old 12th March 2008
sycle1's Avatar
Switched over and been using the Castrol GPS synthetic oil for the last 10,000 k's or so,
in engine and primary.
No problems here.
Old 7th September 2012
Allnighter's Avatar
Allnighter Allnighter is offline
Sportster/Buell Model: XL1200x 48
Sportster/Buell Model #2: Soon
Allnighter is a name known to allAllnighter is a name known to allAllnighter is a name known to allAllnighter is a name known to allAllnighter is a name known to allAllnighter is a name known to allAllnighter is a name known to allAllnighter is a name known to allAllnighter is a name known to allAllnighter is a name known to allAllnighter is a name known to all
I use Royal Purple, A lot quieter than Syn3. $95 for 5ltrs. Engine & Primary. My mechanic recomended it. Actually, it's all he uses.
Old 10th November 2012
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
Torco goes in my race engine. V-Series ST. You really should check these guys out.
http://www.torcousa.com/products-powersport.html
I USED to use HPR50.
