Last Post: Turbo Sporty 48
0 This place still sucks!!!
0 Sportsters No More?
0 Rear shocks ?
0 Can you ID this bike?
0 Tire Pressure 1979 XLH
0 Can't clear unread messages
0 0Salt Flat Sporton
0 New Dakota Digital speedo/tach...
Last Post: TheBreeze
Last Post: Skeezix
0 Chinese S&S carbs
Last Post: Serious Blac
0 Another Test In REAL Snow, More in-depth than...
0 Hard to find Neutral
4 Rear Lighting WIRING help
Last Post: jsaintmartin
0 DK Customs Air Intake
0 How many helmets?
Last Post: Marsikus
0 MagnaFlow Riot collector
Last Post: Conan
0 Ultima Ignition Issues
Last Post: mrmom9r
0 Cant find (2001 Jugs/Pistons On 2005 Engine?)
0 Rear Sprockets
0 Upgrade proof, evidence backed, High Flow Air Filter/intake for EFI 883/1200
Last Post: d10221
0 WTF Happened
Last Post: ZCarFan
0 WTB - 66 xlch rocker box parts
Mr.Gordon, rayzer13 (58), GrumpyCoyote (52), billet93 (48), beast1 (47), Barney_rubble23 (47), DDT (43), mgaworecki (42), superman5a (40), Phoenix81 (40)
Old 17th May 2019
SHAKY DAVE's Avatar
SHAKY DAVE SHAKY DAVE is offline
Sportster/Buell Model: XLX
Sportster/Buell Year: 83
Sportster/Buell Year #2: xlh
SHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to all
Default New WTF Happened
so last Monday I started to put new kibblewhite .002 over valve guides in my spare heads,i had a real problem a few years ago with the shop I used put in stock size guides when they were already .001 over.guides loosened up and almost left me stranded.chumps.had a friend put in .001.s .one in each head and was fine.i was lookin for a hone and my buddy said to use a Dremel to clean up the guide holes.cut down a grinding stone and overbored the first one and when I put the first frozen intake the sucker almost fell thru I about got pissed.any fix?hell i'll look for another late front head but what a bozo move on my part.guess my brain damage from my spill last july really gets me sometimes
Old 17th May 2019
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Bore the hole true and turn a new oversized guide.
Old 17th May 2019
in hindsight a ball hone likely would have worked quite well for that.i've already used one to open up a cast iron lifter block for a .005 oversize lifter.
Old 18th May 2019
SHAKY DAVE's Avatar
how big of a guide can I get?
Old 18th May 2019
it sounds like Mike is talking about having a custom one made to fit the o.s. hole.
Old 18th May 2019
SHAKY DAVE's Avatar
no dough for that.ahh well,need a head I guess
Old 18th May 2019
It only takes 10 min in a lathe to cut down a larger guide.
Old 18th May 2019
Kibblewhite's catalog lists ironhead guides at .010 oversize. So there's 2 options.
Find a way to open the head to fit the +.010 oversize guide, or
As Ryder Rick and Iron Mike suggest,
Reduce the diameter of the oversize guide to fit the current hole in the head, provided you've got a true round hole.
Old 18th May 2019
Ideally, Bore the guide hole concentric to the seat to eliminate the Dremel badness. A reamer may follow any offset from the Dremel handiwork.
Or at least ream it in a mill to get as close to concentric to the seat as possible, or the seat may need to be moved significantly to match the guide position. If one end of the guide hole is worse than the other you should ream from that side to avoid moving the guide hole any more than possible.
Old 19th May 2019
SHAKY DAVE's Avatar
thanks guys.no lathe or any other machine tools.i'll get a kibblewhite .010 over and see if I can make it work.maybe just maybe I can do this
