0 Regulator/rectifier question
Last Post: LenC
0 Do not buy this oil!
0 G'day from London, England
0 Membership $20? am I missing something here?
Last Post: Bryan1976
Last Post: Akdawg
Last Post: mrmom9r
0 883 having trouble shifting
0 1986 Adjustable Push Rod Adjustment
Last Post: 109Countries
0 New Product Sneak Peek!
0 That Stupid F@#$&in' Speedometer
Last Post: Tjfortyeight
0 Bike wobble question
0 Bean in a can (rattling when accelerating)
0 Cleaning or Keeping your Bike Clean??
Last Post: melvinjoe
0 Cam chest vent fitting
0 Sportster T
Last Post: 1200CustomHD
0 Knocking in Front Cylinder Until Warm (Before & After Rebuild)
6 1983 Ironhead- Final wiring
0 No Power to hand controls
0 Dunlop American Elite tires
0 73 Electric Start won’t run after firing
Snuffy (71), cabby58 (62), SmoothyB (53), johnnyB (51), cayey (50), BIGschwerm (44), chief (44), Sporty Accorn (44), Muddypunk (35), Andreas (33)
Old 14th September 2020
granted 409 rusts but it all depends upon application. never take care of it, road salt and such will make it rust. a lot of mfg's will use it on cheaper lines and save the 304 for more expensive vehicles, sorta like a caddy to a pinto.
there is one thing that 304 does do and that is discolor under high heat. like i said, goes to the core, can you improve the look, well to an extent. the suggestion of ceramic coating is a very good option.
I'm not aware of any use of 409 on aftermarket motorcycle exhaust systems. 304 or titanium does stay prettier. Many OE automotive exhausts are 409. The replacement system for my daily driver is 409, Flowmater mufflers are 409. 321 stainless is the "better" stainless for exhaust systems and is the norm on aircraft. The downside to 304 is it work hardens, can be prone to cracking and can't be annealed by conventional methods. The "discoloration" is actually oxidation of the surface, it varies depending on the metal temperature. Scotchbrite pads will remove it but it will come back when the system is run again.
Old 15th September 2020
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
I'd try this: For hand application to revive dull & neglected surfaces without scouring. Removes oxidation, scratches & stains
https://www.meguiarsdirect.com/megui...ound-16oz.html
Old 16th September 2020
NGOT8R NGOT8R is offline
Sportster/Buell Year: 2019
NGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud of
I use Lysol toilet bowl cleaner (applied with a cotton ball). Super easy and no elbow grease needed; just rub on and rinse and watch your pipe be restored to near new condition. I’ve used this method for years with my stainless steel motorcycle pipes.
beard.tailor beard.tailor is offline
Sportster/Buell Year: 08
beard.tailor is an unknown quantity at this point
Thanks for the heads up, going to give it a try.
Sent from my SM-G950U using Tapatalk
