0 Hydraulic Lift For XL
0 question for our machinists
Last Post: yoshi
0 supply oil line seeping
0 Fact or fiction?
0 Cometic Air Cleaner Gasket?
0 Fork Upgrade to 39mm. Is This Possible/Wise
Last Post: Nacs
Last Post: olrider
0 Interview of My Expieriences Riding in the Iron Butt Rally
5 Crankcase Oil Drain Plug
0 Winter riding clothes
0 Question on priming motor for kickstart
Last Post: kobra50
5 Your worst car?
Last Post: dodgetrucken
5 73 Timing w/Strobe & 77 air/fuel screw
Last Post: 4th of July
Last Post: 619Sporty
0 A.I.M. Clutch set up
0 What engine oil do you use?
carb, idle, misfire
Old 7th June 2012
djiroc420 djiroc420 is offline
Sportster/Buell Model: xl1200s
Sportster/Buell Year: 99
Sportster/Buell Model #2: xlc
djiroc420 is an unknown quantity at this point
Default 05 misfireing an wont idle
im trying to get an 05 sporty 883 running smooth again. It was running fine an had a carb adjust problem we got help from you guys on here. So we put in a s+s super e carb and a new ignitoin module and coil. Bike was running and sounding great until the last few days were rain. Now the bike is popping an misfiring. We also noticed that only the front cyl in warming up. I replaces the plugs and wires an still doin the same thing. any help is like always much appreciated. and if there is any other info needed let me no thanks again fellas
Old 7th June 2012
its an 04 also sry about that
Old 7th June 2012
Rico 05R's Avatar
Rico 05R Rico 05R is offline
JESTER SYNDICATE
Have you checked for trouble codes? Could be the Crank Position Sensor.
Old 7th June 2012
JohnK's Avatar
JohnK JohnK is offline
Sportster/Buell Model: Dearly Departed XL1200C
Other Motorcycle Model: FXDL Low Rider
Other Motorcycle Year: 2000
JohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant future
+1 good first steps, just bear in mind a partially failed crank sensor won't always throw a code. Also check your battery connections and grounds... take them off, clean and replace securely after checking them for breakage.
John from Windsor Ontario
'00 FXDL
Old 7th June 2012
semjpm semjpm is offline
semjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to all
Rain and spark plug covers don't mix. I forget the official Harley name for them but they bolt up and go over the plugs., Any water and they short the spark to ground.
SEMJPM
