0 TC88A EEPROM or FLASH
0 Brake pedal adjustment on 09 Custom
Last Post: 83ironman
0 Needspeed please contact me below
Last Post: Monte03
3 Shaky Dave Recovery
Last Post: Serious Blac
0 Tools
0 rear brake combo
0 6 speed
0 1250 break in map for tc88a
Last Post: dewjantim
0 forged pistons?
0 (How to Needed) TC88A ignition module donated to me
0 883 cc >> 1200 cc big bore conversion
Last Post: lovevoodoo
0 Getting Hammered
Last Post: Ghostdog
0 8th Air Force memorials in the UK
Last Post: a-sad-anorak
0 Mid West Meet & Greet
0 WTB:2003 Tank Badge
Last Post: BlackBikeDave
0 Bought a '74 today.
Last Post: XL100
0 First real ride
1983, charging problem, generator, ironhead, xlh
Old 7th July 2015
Steelhead760 Steelhead760 is offline
Sportster/Buell Model: Xlh 1000
Sportster/Buell Year: 1983
Steelhead760 is an unknown quantity at this point
Originally Posted by brianbbs67 View Post
Glad you got it going, but your thread cursed me. I just went thru the same troubleshooting on my generator, and yep Electronic regulator toast!..........
Damn man I'm sorry!!! maybe it was just that time though!!!
Old 7th July 2015
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 1970
Other Motorcycle Year: 1977
I can't complain really, it was from 1985!
Old 7th July 2015
Lol Totally i believe the one i had on there was original as well from 83'
I appreciate your insight though man!
Old 7th July 2015
scottfisher's Avatar
scottfisher scottfisher is offline
Sportster/Buell Model: FLCH
Sportster/Buell Year: 61
Sportster/Buell Model #2: XLCH Kit Bike
Sportster/Buell Year #2: 60
scottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to behold
Carb related? Please do elaborate, i am having some problems with my carb as well since i bought her as a project, it will only run well on reserve even on a full tank, sputs out and backfires bout 1/2 throttle while fuel is on.
Disconnect your fuel line and check your fuel flow and or dump the fuel out of your tank...you may have some dirt/debris caught on your petcock screen.
s
Scott
'61 'CH
'60 'CH
See No Evo, Hear No Evo, Speak No Evo, Ride No Evo
Old 7th July 2015
hcrashster's Avatar
hcrashster hcrashster is offline
Sportster/Buell Model: XLH Spinegrinder
Sportster/Buell Model #2: XLCH Frankenstien
Sportster/Buell Year #2: 1976
Other Motorcycle Model: Triumph Groanyville
Other Motorcycle Year: 1972
hcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud of
I don't want to run into more genny problems in the near future, so will my carb in that condition screw with my reg again?
So sorry, the joke comes from a maxim often repeated on this forum; "Most carb problems are electrical in nature".
Let's see about your carb.
Going to need the maker, rebuilt yet? fuel flow from tank, [As our esteemed Canadadian brother pointed out], is the bike tuned up? etc.
As with most of the stuff bolted on to the bike, the carb is interrelated to everything else. That is, when one link in the chain ain't right a problem can arise somewhere else....which goes back to the joke once again.
Post some info please.
PS. You are smart enough to work on your own bike. That's good as these poor things were and still are, the most abused bikes ever seen till we get our hands on them and fix them properly. If you don't already have the Factory Service Manual, [and to a lessor extent, the parts manual], it's in your best interest to get em.
We are for the most part, on our own as far as fixing these old scoots. The dealers won't have anything to do with them and the aftermarket parts market is getting dryer by the year. Noob? I'd say your miles ahead of all the costume wearing "riders", out there.
Once again post back some info.
Ordinarily he is insane, but he has his lucid moments when he is only stupid
Old 10th July 2015
wymanv's Avatar
wymanv wymanv is offline
wymanv will become famous soon enoughwymanv will become famous soon enoughwymanv will become famous soon enoughwymanv will become famous soon enoughwymanv will become famous soon enoughwymanv will become famous soon enough
Cool
Did you do it this way, with good grounds?
9. Here's a good way to bench test your generator:
Contributed by Bowtied
1. connect a jumper from the "+" battery post to the "A" armature terminal on the gen.
2. Connect a jumper from the "-" battery post to the "F" field terminal of the gen.
3. Now take a third jumper from the "-" battery post and touch it to the case of the gen.
If all is well the generator will run like an electric motor. With the gen gear pointing away from you the rotation is clockwise.
Gotta bump this thread because I have an issue here.
What if it spins counterclockwise?
Background: 1977 XLCH, no reason to believe this generator has been replaced before I got it. Performed well until the "last days" when I had to run the bike off the car battery because it would die when I took the jumper cables off the (very old) battery. During the teardown I found the brushes were worn right down, so it got the J&P rebuild kit. Double/triple checked all the connections to the pics posted in the threads here and in the stickys and it all looks correct.
But it spins counterclockwise... Or not at all if it's hooked up the other way.
Any ideas?
Ken
Arrogantly twisting the sterile canvas snoot of a fully charged icing anointment utensil...
Old 11th July 2015
sound's like it need's to be,polarized.the F.S.M. give's the instruction's.
Old 11th July 2015
wymanv's Avatar
Cool
Did. Made no difference.
Ken
Old 11th July 2015
Any ideas?
Ken
Hooked up the other way? What do you mean?
What brand is the Genny?
S
Old 11th July 2015
wymanv's Avatar
Cool
Positive to the F, ground to the A.
S
65A, factory original, for all I know. Nothing on the case/housing says otherwise.
Ken
edit: On further review:
Harley Davidson
A Made in USA F
65A-12V
