0 question for our machinists
0 *DK Custom - Our Gift to You - Holiday Savings*
Last Post: Yakcm2
0 Fact or fiction?
0 You can't tour on that!!!
Last Post: RDHenley
Last Post: herostar
0 Black Friday/Cyber Monday Showoff Thread
Last Post: herostar
0 XLCH Plunger Seat Kit
Last Post: FatboyBill
0 hi all
Last Post: early iron
0 Swingarms
0 the roadster make more power ?
0 supply oil line seeping
0 Question on priming motor for kickstart
0 Interview of My Expieriences Riding in the Iron Butt Rally
0 Hydraulic Lift For XL
0 3.5" straight riser
0 Cometic Air Cleaner Gasket?
0 Fork Upgrade to 39mm. Is This Possible/Wise
Last Post: Nacs
Old 12th June 2017
brap818 brap818 is offline
brap818 is an unknown quantity at this point
Default Belt Tension Adjustment
I'm doing a belt adjustment tomorrow and the service manual states that to make sure the wheel is on the center of the fork when done. Should I align the wheel first or just proceed straight to adjustment?
2009 XL1200L.
Old 12th June 2017
Sprtstr1200s's Avatar
Center the wheel FIRST. Cut the straight section off a metal coat hanger, bend a 90 on one end. Saves buying a tool.
Old 13th June 2017
wedge's Avatar
wedge wedge is offline
FWIW. I run the drive belt looser than spec. My original belt broke early in life, and the new one has outlasted it by double so far. I use the spec for play, but I make that "free play" rather than use the 10# pressure tool on it. The bike feels way better in corners with the belt looser. The tighter adjustment seemed to affect the bike in corners (like it wanted to lift the rear under acceleration).
Old 19th November 2017
JunkyardDog JunkyardDog is offline
Other Motorcycle Model: Kawasaki Vulcan 750
Other Motorcycle Year: 2002
JunkyardDog is an unknown quantity at this point
While you can use a coat hangar or a tape measure, I got the Motion Pro tool. It is not expensive, and I believe it is a bit more precise. I believe a belt drive needs more precise alignment than a chain. I also run mine just a little loose, but I do use the 10 pound gauge for consistency. I've heard you are supposed to have someone sitting on the bike when making the measurement, but that is impossible for me to do, so I just do it with the bike unloaded, sitting on the wheels.
I refuse to give up the risk of living for the safety of existence
Folkie Folkie is offline
+1 on the Motion Pro tool.
