9 CV carburetor gurus...
Last Post: 83XLX
Last Post: Bow only
0 1970-71 XL Fuel Tank ?
Last Post: 72 Ironhead XLH
4 greetings from quarantine!
Last Post: Joe_jeep
14 Installed Vulcan 3 Degree Raked Cups
0 Diagnostic code ?
0 Resto-Repair 84 ironhead
Last Post: Kbetts
0 Who runs 70wt. oil
Last Post: Kbetts
0 Low Profile Scissors Lift
0 1960 XLCH in the UK
0 Spark Plugs
0 Leineweber camshaft
0 Clutch cable help (length)
0 Oil pump, ignition coil, head pipes, baffles
0 Magneto upgrade questions
0 2019 xl1200 suspension upgrade
Last Post: Bob F
  #31
Old 14th August 2005
sportysrock's Avatar
Sportster/Buell Year: '96
Sportster/Buell Year #2: '72
I checked it again 'hot' and loosened it slightly. It makes a minor whirring noise at about 1500 RPM but goes away near 2000 and doesn't come back so there doesn't seem much to worry about. Another 'cold' check may be in order for the xxxxxx of it.
Old 22nd August 2005
acenorm's Avatar
acenorm acenorm is offline
Other Motorcycle Model: Honda XR400
Other Motorcycle Year: 1998
acenorm has a spectacular aura aboutacenorm has a spectacular aura aboutacenorm has a spectacular aura aboutacenorm has a spectacular aura aboutacenorm has a spectacular aura aboutacenorm has a spectacular aura aboutacenorm has a spectacular aura aboutacenorm has a spectacular aura aboutacenorm has a spectacular aura aboutacenorm has a spectacular aura aboutacenorm has a spectacular aura about
I need a suggestion on how to loosen the lock nut on the adjuster. Can I just put a set of vice grips on the bottom of the bolt? I went to break the lock nut off and the whole bolt spun, so the nut is still "locked". Any ideas, or did anyone else run into this problem? Thanks
Best Regards,
Norm
ZanexGt's Avatar
ZanexGt ZanexGt is offline
Sportster/Buell Model: XL883C
ZanexGt is an unknown quantity at this point
I don't have my manual in front of me otherwise I'd look it up myself but ...
Is there a special tool needed to adjust the primary chain tension using Hero's method?
I'd really like to try it w/ the engine running since it sounds relatively simple.
ZanexGt
'05 883C Black Cherry
| TC88A | Mustang Vintage Wide w/ Pillion | Cycle Shack Slash Cut Slip-On's | Turbota/Xena Style Round Air Cleaner | 45 Pilot / 175 Main (1 Shim) | Super Brace | 29 Tooth Pulley | One Big @ss Grin |
xena's Avatar
xena xena is offline
Assistant Administrator
Nope. Regular wrenches. I did mine using Hero's method.
XLF Rules/Guidelines
XLF Guidelines II
1212 Conversion 10:1 CR
SE 497 Cams, E1 clutch, Python 3 Slip ons
TC88A running Xena's (brand new) White Tiger Map
My 1212 Conversion Thread
Old 23rd August 2005
Best Regards,
Norm
If I remember it's a 1/4 Allen and 7/8 wrench. Sounds like if you snug the nut back up it should be close to where you started, then hold the Allen while loosening the nut.
I did the reverse to tighten it up. Adjusted chain, held Allen Bolt, Snugged nut, and finish torqued nut to spec.
Good luck.
acenorm's Avatar
I finally figured it out. I felt around the bottom of the bolt and found that there was an allen fitting to hold the bolt. The manual didn't say anything about it, and that was what was throwing me off. It is all adjusted, and it seems better. The only other thing I had a problem with was when I was replacing the inspection cover, it doesn't seem flush to the primary cover on one side. I don't know if it was to start off with, but I tried fixing it 3-4 times, and it comes out the same way each time. I tripled checked the o-ring each time, and there are no leaks after one short ride, so I guess it is fine.
Best Regards,
Norm
01Sporty's Avatar
01Sporty 01Sporty is offline
Keep On Keepin' On
Sportster/Buell Model: Pulled to the Darkside
Other Motorcycle Model: FLHTCI
01Sporty is an unknown quantity at this point
Best Regards,
Norm
I had the same thing, then realized the inspection cover has to go on a particular way, try turning it 180 degrees.
Good Luck,
acenorm's Avatar
I already tried that, but I'll take another look at it tonight. Thanks.
Best Regards,
Norm
01Sporty's Avatar
Keep On Keepin' On
I figured that but also thought it was worth mentioning.
Have Fun,
ZanexGt's Avatar
Originally Posted by hero
By 'loading up' I mean slowly increase the preload on the tensioner. No need to have the rear wheel turning or even on a lift. Only the engine running, as the whine is audible with the bike standing still. Might be an even clearer whine if you GENTLY twist the throttle between each turn of the adjuster.
Ok, I plan on tackling the adjustment of my primary chain today or tomorrow. The way I see it, this is how to do it.
1. Loosen up the Nut to make adjustment of the allen bolt inside possible.
2. Turn the allen bolt to tighten the chain
3. With the bike running and in neutral, view the primary chain through the inspection window for slop. (Do we need to check the chain w/ engine offas well?)
4. Listen for audible whine
5. If no whine, turn adjuster until whine appears and then back off the allen bolt adjuster 1/8 of a turn.
6. Test rev engine for whine sound.
7. If no whine sound, tighten up bolts and then you're done.
Is this correct all? I am a little unsure of #3. Do I need to even take the inspection cover off the bike?
Thanks ...
