0 Getting Hammered
Last Post: kltrkmpf
0 Leineweber camshaft
Last Post: chevelle
0 question for our machinists
Last Post: JonesL
0 More oil return questions
Last Post: Scott
0 WTB: Sportster Shift Lever
Last Post: tussuck
0 Mid or forward controls.
0 2015 sportster charging
Last Post: Scott
0 Cheap 7200B bearing = NO!
Last Post: Roane
7 Ironhead yes or no
0 New Member and a question
0 piston rings
Last Post: Sprtstr1200s
0 New member softail rim laced to sportster hub
0 Cold weather pants:
Last Post: RDHenley
0 Electrical question
Last Post: RDHenley
2 Humble pie
Last Post: RDHenley
ironhead, timing
Old 12th March 2016
https://compufire.com/harley/ignitio...n-modules.html
I use the dual fire but available single ( p/n 20100 dual ) about 120 bucks, no bells and whistles been running since 1975. for a few bucks more, ultima from jireh cycle and get the gold cup.
Old 13th March 2016
Mosey Mosey is offline
Sportster/Buell Year: 1982
Other Motorcycle Model: FX
Other Motorcycle Year: 1976
Cheesy, are you timing on the compression stroke?
Old 29th March 2016
Cheesymouth666 Cheesymouth666 is offline
Sportster/Buell Year: 1973
Cheesymouth666 is on a distinguished roadCheesymouth666 is on a distinguished roadCheesymouth666 is on a distinguished roadCheesymouth666 is on a distinguished road
i would like to have the advance its a bit fun to just tinker with things sometimes where could i buy a compu-fire ignition system
Old 29th March 2016
oh thanks it refreshed
never mind
Old 29th March 2016
yes i believe i am timing it on the compression stroke
Old 30th March 2016
Put yer thumb over the front spark plug hole while rotating the rear wheel (yeah, it's a bit of a stretch) and feel the air pressure. Ya gots to be certain.
Wait a minute...you are doing a static timing correct? For static timing you gotta find compression on the front cylinder.
Or are you using a timing light with the motor running? If so, disregard any of the nonsense that I wrote and worry not about compression.
Old 30th March 2016
Thanks for the reply, I am doing the static timing so get someone to turn the wheel while i feel for it to start to push air out of the front cylinder then get it to the advance mark and set the timing using the advance on the timing cam and should i use the small lobe to time on?
Old 10th June 2016
I got the compufire dual fire electronic ignition and installed it but i cant get spark i know the 73 has a positive ground wondering if that has anything to do with it
