0 New Member and a question
0 question for our machinists
Last Post: spuggy
0 Cold weather pants:
Last Post: RDHenley
0 New member softail rim laced to sportster hub
Last Post: RDHenley
Last Post: Roane
Last Post: denguy
0 Electrical question
Last Post: RDHenley
7 Ironhead yes or no
Last Post: spuggy
0 Getting Hammered
Last Post: andy_t
2 Humble pie
Last Post: Sprtstr1200s
Last Post: RDHenley
Last Post: Blue Scoot
0 oil return for stroker
0 Bobtailing a sportster
Last Post: 45Brit
0 Codes again !!!!!
Last Post: 93trident
0 77 XLH Starting issues no needle bearing in primary?
Last Post: MadMike_1126
Last Post: a-sad-anorak
Last Post: RDHenley
5 Your worst car?
Last Post: Traxx
1966xlch, xlch
Old 14th March 2016
66sporty 66sporty is offline
Sportster/Buell Model: Xlch 900
Sportster/Buell Year: 1966
66sporty is an unknown quantity at this point
Default 66 Xlch Rev Problem
Hello have a 66 xlch with tillotson carb rebuilt
Bike starts on 1-2 kicks
When I close choke it just stays revving uncontrollably carb tuning does not change it.
Any help is appreciated
Old 14th March 2016
Magneto Sportster's Avatar
Magneto Sportster Magneto Sportster is offline
Sportster/Buell Year: 1969
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1960
Other Motorcycle Model: XLCH
Other Motorcycle Year: 1959
Magneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond repute
Does it have the stock throttle cable setup? If so, do you have the cable adjusted properly so that the throttle is able to close all the way?
"Ride 'em, don't hide 'em!"
Old 14th March 2016
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
I run that carb and have not had that issue. If your positive there is no intake leak then check the throttle cable adjustment
Old 14th March 2016
Throttle is fully closed checked that and cable is adjusted
not a fan of the dead man throttle
Changed bars and put a external throttle single cable with a spring on carb so it snaps back have checked to make sure it wasn't sticking and spring returns to closed
Old 14th March 2016
If I understand you correctly ,you have a rebuilt carb.
It could be that the throttle plate is installed backwards not allowing the plate to close all the way
Old 14th March 2016
Silly question, but you did set the idle adjustment screw correctly, right?
Old 14th March 2016
Yes have checked idle screw does not change revving at all
Old 14th March 2016
Then the throttle plate is backwards
Old 14th March 2016
Originally Posted by 66sporty View Post
Throttle is fully closed checked that and cable is adjusted ...
Did you check this by removing the A/C assembly and observing into the carb venturi while twisting the throttle? Engine does not have to be running for this.
Old 21st July 2016
GA_Ironhead GA_Ironhead is online now
Were you able to fix the problem?
Merely dying will not get your name removed from the enemies list!
