0 Hydraulic Lift For XL
0 question for our machinists
Last Post: yoshi
0 supply oil line seeping
0 Fact or fiction?
0 Cometic Air Cleaner Gasket?
0 Fork Upgrade to 39mm. Is This Possible/Wise
0 Very Loud Backfiring (among other things)
Last Post: Nacs
Last Post: olrider
0 Interview of My Expieriences Riding in the Iron Butt Rally
5 Crankcase Oil Drain Plug
0 Winter riding clothes
0 Question on priming motor for kickstart
Last Post: kobra50
5 Your worst car?
Last Post: dodgetrucken
5 73 Timing w/Strobe & 77 air/fuel screw
Last Post: 4th of July
0 Speedometer Interchangeability Between Different Generations.
Last Post: 619Sporty
0 A.I.M. Clutch set up
0 What engine oil do you use?
  #861
Old 18th January 2018
cycowrencher's Avatar
cycowrencher cycowrencher is offline
Other Motorcycle Model: 1984 KX 125
cycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud of
Originally Posted by Vohnsen View Post
i run a 530 non oring chain now..... this is a track race bike only.. will never see the streets
You can also have your 530 sprockets machined for a 520 chain. The pitch is the same, but the 520 is narrower. Have the sprockets machined on the inside and you will gain additional tire clearance. with the added benefit of cheaper chains...
For reference: hex head 3/8-16 hex head bolt head thickness is 0.2344 inch. Button head 3/8-16 bolt head thickness is 0.199 inch.
USN 1991-1995 VFA-81/ USS Saratoga, Iraq 1, Kosovo/ Bosnia Conflict
Vohnsen Vohnsen is offline
Vohnsen has a spectacular aura aboutVohnsen has a spectacular aura aboutVohnsen has a spectacular aura aboutVohnsen has a spectacular aura aboutVohnsen has a spectacular aura aboutVohnsen has a spectacular aura aboutVohnsen has a spectacular aura aboutVohnsen has a spectacular aura aboutVohnsen has a spectacular aura aboutVohnsen has a spectacular aura aboutVohnsen has a spectacular aura about
yeah i 520 is about 3 mm smaller than a 530... how about chain strenghts for dragracing.. ?
https://www.youtube.com/nikolaiownz - Homemade dragbike with Stock XL1200 '98 engine.
mac93 mac93 is offline
Sportster/Buell Model: 1200
Sportster/Buell Year: 95
We’ve been running the 520 chain four season now without problems. The last two seasons with a 90 inch engine. They come in different tensile ratings, we’re using one of the stronger chains, can’ remember exact numbers but 8800 sounds right.
Vohnson, Macs bike is a Sub 9.60 @130+mph machine.
Old 20th January 2018
yeah i hear ya.. i hope i can run a shinko 180 without problems.. or else i will go 520..
I am redoing my rear end/chain tensioner on the frame since i dont have enough space there... will be machining new aluminium blocks for the axel and tensioner so i hope i can make more room.
Old 24th January 2018
Step 3:
1/2 Hiems
Old 28th January 2018
Took 4 inches out of the front.
Sent from my LGLS992 using Tapatalk
Old 29th January 2018
Battery box, tank and oli tank mounted....
All rubber mounted to avoid anything breaking in the welds and shit..
I am gonna pickup my pegs set ... will need to fab the mounts up.. i got clipons on the way and 1/4 quick turn throttle..
Old 30th January 2018
jcro61 jcro61 is offline
jcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud of
Started mocking a few things up...
this isn't just a trend homie, it's a lifestyle...
Is that at ride height?
