5 02 Sporty speedometer wiring
Last Post: budoka
Last Post: mac93
Last Post: smilinbrad
0 Timing
0 Powerraythor conversion
0 Fat Ironhead?
0 Locked up rear wheel
0 Experts advice needed
0 Leineweber camshaft
0 Getting Hammered
0 Alto Carbonite Clutch Kit - 095750BC - ‘91+ XL/Buell - Brand New
Last Post: wrkdWS6
Last Post: johnwesley
0 Engine Tune
Last Post: Randy_rots
Last Post: Blowupster
carb, keihin, mod, twinshot, upgrade
Old 24th October 2017
rocketmangb's Avatar
I saw no mention of motor work in the OP.
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
drgonzo21's Avatar
drgonzo21 drgonzo21 is offline
drgonzo21 has much to be proud ofdrgonzo21 has much to be proud ofdrgonzo21 has much to be proud ofdrgonzo21 has much to be proud ofdrgonzo21 has much to be proud ofdrgonzo21 has much to be proud ofdrgonzo21 has much to be proud ofdrgonzo21 has much to be proud ofdrgonzo21 has much to be proud ofdrgonzo21 has much to be proud ofdrgonzo21 has much to be proud of
I don't see where anyone suggested re-jetting a CV40 would get you 90HP.
i run a 200 main and if i discount the engine mods, i doubt the 180>200 change would give much more over stock. it would have probably experienced mix issues and a drop in mpg.
the thing is, it has to be a system that plays well with each other. if you change one thing, high chance you changed something else.
i have long said i need to copy rocketman's build as the carb goes since i am hobbled at present and the machine could go some more with what i have mod wise.
if you observe the builds by others, you get a great insight as to what does and what does not. do i feel ashamed i copied, nope!! maybe the guy i left behind will.
a vast sea of knowledge abounds here, just need to navigate your boat to your goal.
Old 27th October 2017
harley506d's Avatar
Sportster/Buell Model: 1200c
Just checked mine,
Main-160
Slow-45
Needle -N9EY +1shim
So i am guessing totally stock? or has someone put a shim in?
Runs superb apart from slightly woolly in the mid range. Might go for a different needle.
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Originally Posted by harley506d View Post
Slow-45
Stock slow jet is 42, not 45.
Folkie
South East England Riders
XLXR's Avatar
XLXR XLXR is offline
Most of the information you seek has already been figured out ...... decades ago, and well documented in the carb sticky section. (I think) Hammer performance has dyno sheets that demonstrate the hp limitation of the CV carb. At some point in desired hp and cost, a Mikuni carb makes more sense than modifying a CV. The main advantage of a CV is it maintains air fuel mixture over a wider range of altitudes.
No carb will work properly if not set up correctly to match engine and various mods. As you stated before, the hard part is shifting through all the BS.
Neither was the needle shim !
That may have come with a 175 main so you could be lean now
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
42/180 is stock on the 05 1200. No shim.
Mine had a 45/170 with the dynojet kit but dynojet jets also don't flow the same as stock jets nor does the main fit in the stock emulsion tube. The dynojet tube has like 2 or 3 holes in it. The stock one has like 15 or something like that.
Old 28th October 2017
The Crusher's Avatar
The Crusher The Crusher is offline
The Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond repute
Best upgrade I can think of would be an EZ-just mixture screw. That way you can easily tune for conditions, like a cold morning and a hot afternoon or heavy humidity. I go out some early mornings it's 35-40F, then warms to 75-80F. That's a big swing from lean to rich.
You've always got to remember
Hotter Air ................................................. = Less Oxygen :- Richer
Colder Air ................................................. = More Oxygen :- Leaner
Higher Barometric Pressure Or Low Altitude....... = More Oxygen :- Leaner
Lower Barometric Pressure Or Higher Altitude ... = Less Oxygen :- Richer
Higher Humidity.......................................... = Less Oxygen :- Richer
You can't keep a good man down......... unless you tie weights to his ankles.
XLXR's Avatar
Adjusting air mixture screw has greatest effect at idle to 1/4 throttle settings, but has minimal to no effect at half to full throttle.
