0 Leineweber camshaft
Last Post: RDHenley
0 Mid or forward controls.
0 buckhorn bars
Last Post: 11alan111
Last Post: Larry May
0 Next please (ICM Learning Cycle)
Last Post: 93trident
Last Post: SLW210
0 Powerraythor conversion
0 Getting Hammered
5 02 Sporty speedometer wiring
0 Dynojet Target Tune and/or autotune with PV
0 A Day in the Life...
Last Post: Bigshankhank
0 The show me your winter beater thread
Last Post: mac93
0 Timing
0 Fat Ironhead?
0 Locked up rear wheel
1200s, carb, colorado, jets, mikuni
Old 21st April 2018
ianmattxl1200 ianmattxl1200 is offline
Sportster/Buell Model: 2000 Sportster S rigid
Sportster/Buell Model #2: xl1200s
ianmattxl1200 is an unknown quantity at this point
Default Mikuni HS-42 on 2000 1200S
I have a 2000 1200S and have just installed a MIkuni HS-42 carb. Started and idled great. I am curious if any of the board member have this card on a 1200 and live in Colorado or similar elevations and what was you best jet size in tuning? Stock was a 160 main and I installed a 155 for first start. I do have 2-1 thunderheaders. Thank for the input.
Old 21st April 2018
rocketmangb's Avatar
What pilot did it come with ?
Does it have the correct throttle cable bracket for a Sportster ?
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 28th April 2018
yes single throttle cable is working fine. I have the 155 jet in there now and seems to be only tad rich smelling. might try 150. I believe they added these jets to my kit on ordering knowing that I live in Colorado via my zip code. Surely there is someone with a 1200 sportster in colorado running a Mikuni and have messed with the jetting. i know I can read plugs etc but was curious what others ended up going with. Thanks for the input.
Old 28th April 2018
Seems Mikuni has a "dream"wheel for altitude correction
Old 28th April 2018
How so? Sounds interesting.
Old 28th April 2018
Lookie Here !
https://www.amazon.com/Mikuni-Carbur.../dp/B0012TUUHG
Old 29th April 2018
looks like it came with the stock main jet which is a 160 and the needle has already been leaned out by moving the clip up one spot. i have the 150 jet in now and seems to be running the same. fresh new plugs look fine after long ride.
