0 55* this morning
Last Post: Skeezix
0 Microsquirt EFI Conversion
Last Post: Randy_rots
0 Chasing a generator noise
0 KBS tank sealer
Last Post: Len PA
0 starting rollers
0 Tools
Last Post: ReddTigger
0 Covered shocks
Last Post: Reverend G
0 Potato-potato
0 XR750 resurrecting
Last Post: Big Al
0 carbs?
0 77xl sportster
Last Post: Mr Snoid
Last Post: bklyngeezer
0 2007 883R From Sunny Old England!
0 "She" bolts
0 Long vs short stem mirrors for 1980 fitment
Last Post: blk80bike
0 Better Brakes
Old 24th July 2019
NLXL's Avatar
NLXL NLXL is offline
Sportster/Buell Model: XL883DLX
Watch what you carry on a belt. Don't let it end up by perforating a kidney or a spleen in case of an accident...
Old 24th July 2019
Highly-Dangerous's Avatar
Highly-Dangerous Highly-Dangerous is online now
that´s nasty!!! but you´r right! obviously... Common-Sense should be applied!!!
Knife goes in my thigh-bag (or in a magazine holster in my pistol holster), Pistol in a shoulder-holster.
[B][COLOR="Red"]CLICK->>[/COLOR][URL="http://sportsterpedia.com/doku.php/start"]"Maintenance is as much art as it is science"[/URL][COLOR="red"]<<-CLICK[/COLOR][/B]
[IMG]http://xlforum.net/forums/attachment.php?attachmentid=20617&d=1576580635[/IMG]
Old 25th July 2019
dieselvette's Avatar
And there is room for more.
Good call on the alligator clips - with two more and some wire, you also have jumper cables.
____________________________________________
FIND HELP WITH YOUR SPORTSTER HERE: http://sportsterpedia.com/doku.php
If men can build it, men can fix it. - Tim Allen
2004 1200 Roadster Custom-Electra-Glide-Sport-Touring-Edition
SE air cleaner w/venting routed outside a/c
Supertrapp 2:1 pipe - usually 20 discs w/closed endcap
Stock CV carb w/ Yost tube + DS idle mixture screw
Cycle Electric 38A charging system
TC88A ignition
0.030 head gasket, zero deck-height
Hammer 570 cams
Bronze oil pump gear, updated oil pump
30-tooth HDI belt sprocket (137-tooth belt)
Old 25th July 2019
SLW210's Avatar
SLW210 SLW210 is offline
Sportster/Buell Model #2: FXLR Low Rider
Sportster/Buell Year #2: 2019
SLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond repute
Cell phone in front left pocket, pocket knife clipped inside front right pocket and a billfold in right rear pocket.
I have roadside with my insurance and $100 worth of tow with my HOG membership until it runs out.
I have never had a single scratch or micro scratches in a face shield that could be attributed to a paper towel. If a wet paper towel would damage it, then might as well leave the bugs and dirt on it, because they are much more abrasive. Unless it's an emergency and I can't see, I usually clean it when I have a source of running water to rinse off before doing any rubbing on it.
Slime and Ride-On (both available for inner tubes and motorcycle use) are supposed to be non-corrosive to wheels according to the manufacturers. Though I don't use them. Would beat walking or waiting in the cold, rain, heat for help to arrive if far from home.
I did carry a few things when I had a bag on the bike.
I have a leatherman and several similar pouch tools, but, I don't take them with me.
You should carry Duck Tape or Gorilla tape instead of (or along side) electrical tape IMHO, I prefer Liquid Electrical tape.
Old 4th September 2019
Bump!
Old 5th September 2019
45Brit 45Brit is offline
Sportster/Buell Model #2: 1978 XLCH project
Other Motorcycle Year: 1975
45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute
6” adjustable spanner
13mm and 11mm spanner’s, one open end, one swivel ratchet end
Allen keys including the ones for the handlebar levers and Supertrapp discs...
Torx key for the little covers on the transmission
Screwdriver, straight and crosspoint
Plug spanner and one plug
Insulation tape
Some tie-wraps
A few nuts and bolts and washers
Small clean rag
Leatherman tool
Maglite
Old 30th May 2020
RDHenley's Avatar
RDHenley RDHenley is offline
Sportster/Buell Model: XL883C
Sportster/Buell Model #2: XL883C
Sportster/Buell Year #2: 2002
Other Motorcycle Model: Street XG500
Other Motorcycle Year: 2015
RDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond repute
Default Rider repair
There's some great suggestions for bike repair, but don't forget a little kit for rider repair. Boo boos happen without warning, and it's good to have a few of the common things for dealing with it, especially if riding in rural areas where a 20 minute response to a 911 call is common. The better half was running the chase vehicle for a group ride to Bishop's Castle recently and someone dumped their bike, and her first aid kit was all they had for an hour, in part because the first two passersby that they asked to call 911 when they got back to cell phone signal apparently didn't do so. (In my four wheelers I carry a kit that would make most EMTs proud, and that day it was a good thing.) Quite frequently on rides I've had to deal with cuts from stones or other debris thrown up from the road, minor abrasions from parking lot spills, and bug bites and stings. Not many riders carry a first aid kit, and far too many don't believe in dressing for the slide.
At minimum a dozen or so band-aids, a tube of triple antibiotic ointment (Neosporin is one brand), some alcohol wipes, and a couple pairs of latex disposable gloves. (That last can do double duty for mechanical work to keep your hands clean if messing with something oily.)
My little kit for the bike also includes a dozen 4x4 pads, a couple rolls of medical gauze (Like Kerlix brand), a roll of medical tape, an Isreali bandage, a couple packets of Tylenol, and a packet of burn gel. All this fits in a small pouch that could be clipped on a belt, or it might take of half the space inside a decent sized downtube bag.
Google "Motorcycle First Aid Kit" and you can come up with some pretty good ideas of what to carry, and even some pre-made kits for sale.
*Silver '05 883C Miss Molly* *Purple '02 883C Robin Marie*
Old 31st May 2020
Great idea! I always carry tool bag items and water bottles but for some reason, this one escaped me. My daughter is an EMT and always has extra stuff like this. Time to give her a call.
Old 31st May 2020
RDHenley's Avatar
Mine too, but the local VFD is usually so short on budget that they don't have anything extra to spare, though occasionally she'll "throw away" the out of date stuff that the date doesn't really make a difference on into a bag for me. She's also a excellent source of advice for what I should have in a kit, and occasionally gives me a refresher on using things I don't normally do. For instance, Israeli bandages are a bit expensive, so I've never actually opened one, but every couple of months she talks me through a refresher so that if the time comes maybe I'll know what I'm actually doing.
Old 31st May 2020
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Jar of honey. Spread on roadrash. Bandaid. A GOOD ONE.
Is how I roll.
Traveled to
