Last Post: Thyratron
Last Post: shaymus
0 And so it begins......
0 Forum problems???
Last Post: CMCSSeabee
Last Post: Texassporty06
0 85 clutch adjustment woes
0 1965 Ironhead in CT
Last Post: Bandit2
6 Is Your SPORTSTER...
0 Trackday Sportster
0 Mag wheel corrosion
Last Post: Magneto Sportster
0 Who's still riding???
0 62 xlch
Last Post: oupa
0 12" or 14"? (Apehangers)
0 Spokes or Mags
Last Post: Desertfox
0 XR1200 belly pan on an XL?
0 my build in my apartment
Last Post: rickthrash99
0 Spokes question
Last Post: Scott
0 compression problems
0 Late Ironhead cases interchangeability
10 Exhaust Pic thread
Last Post: Nayra
Last Post: Adam76
Texassporty06's Avatar
Texassporty06 Texassporty06 is offline
Sportster/Buell Model #2: 883 xlh
Sportster/Buell Year #2: 1986
Texassporty06 is a jewel in the roughTexassporty06 is a jewel in the roughTexassporty06 is a jewel in the roughTexassporty06 is a jewel in the roughTexassporty06 is a jewel in the roughTexassporty06 is a jewel in the roughTexassporty06 is a jewel in the roughTexassporty06 is a jewel in the roughTexassporty06 is a jewel in the roughTexassporty06 is a jewel in the roughTexassporty06 is a jewel in the rough
Default Wiring harness questions
Pretty quick and simple.... Can you do a straight swap with wiring harness from 86 through 03? Or is it year/ model specific, so if I was to swap out my 86 883 with say a 92 883 wiring harness, would there be any issues?
A number of changes in the location of devices occured over the years - that means that the wiring harness runs wires to the specific locations of the devices for each year - It is far from generic...
One difference between 1986 & 1992 is the turn signal wiring - '86 used a auto-type blinker in the headlight & sent the actual flashing power for the lights thru the handlebar switches before going to the lights while in 1992 there was a TS cancelling unit which used incoming signals from the switches to the create power for and run the blinking lights directly from the TS module...
You'll need to consider all the various devices and their locations to determine how much effort is required to make a '92 harness work on an '86 bike - along with any consideration you might have of modifying the locations or eliminating certain devices...
Check Out The Sportsterpedia
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
The simple answer is no. For instance, my '93 has a harness that is specific to its year.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Subscribing Biker
Why the swap? If the '86 wiring is old and fragile, the '92 isn't going to be much better. It's better to make a new harness (with new wire and connectors) using the '86 as a blueprint.
Oh I'm not actually going to swap out a 92 harness or anything, just a general question say for instance I got a whole new frame and found a pristine harness for next to nothing, if it would be a great difference.
