0 Does 20W60 reduce cam gear noise?
Last Post: XL Dane
0 TC88A EX lower MAP settings
Last Post: ZCarFan
Last Post: 81ironhead77
Last Post: fafcpa
0 Hagerty Insurance
Last Post: Pigskinner
0 Poll: Saddlebag Supports
0 magneto twin plug heads
Last Post: marioserafica
0 Fun or money?
Last Post: bill smith
5 Wet Dream, Ever Have One?
0 Down on oil
Last Post: Billy1200
0 1968 xlch
0 blonde, brunette, red?
0 Hamburger drum brake clunk noise
Last Post: nickfracture
11 How much did you spend on accessories in the first month?
0 I'm here to introduce Gristle.
Last Post: apotheon
Last Post: Randy_rots
Last Post: apotheon
0 Wish I had a beach with a ocean
Last Post: Akdawg
10 big bore question
0 Transmission figment
0 Smoke and top end job
win307 (66), JrzyDave (59), WeirdNJ (59), Pigskinner (46), jeepsoldier (44), Virgdog (34), bernardderek, John Titor (22)
883 to 1200, cams, conversion, heads, s&s
Old 23rd March 2011
bluesburke bluesburke is offline
Sportster/Buell Model: XL 883 Hugger
bluesburke is an unknown quantity at this point
Default S&S Super Stock 883/1200 Conversion Head Kit - What's your opinion?
Hello,
I have a 99 XLH 883 Hugger that has been converted to a 1200 by boring out the original jugs. It has S&S 1200 conversion pistons, a Super E, Andrews N2 and RB Racing LSR pipes. It still has the stock heads and valves.
So I've been considering having head work done on the original heads but I have hot found anyone in this region that I trust yet. So another option might be to buy the correct S&S Super Stock head kit (SKU 90-1310...maybe?).
Next comes consideration for the cam. So should I go with a S&S cam to go with this head kit and if so...which one? Maybe go to an Andrews N4?
I'm new to the forum and new to Harley. I have 16 years riding experience on Triumphs and BSA's but I always wanted a Sporty. So now I have my dream sporty to tinker with.
Thank you for any guidance.
bluesburke
Old 23rd March 2011
02883r's Avatar
02883r 02883r is offline
Sportster/Buell Model: 883r
02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all
I've never been overly impressed with S&S heads in stock form.... You would need different pistons as well since the combustion chambers are different. If you are looking for an excellent performing bolt on combination I would recommend buell thunderstorm heads with matching pistons and either Andrews N4 or SE .497 cams. That particular combination with proper tuning (and good carb, exhaust and ignition) will make between 85 and 90 hp easily (I believe mine made in the ballpark of 89 hp with that combination. You can get the thunderstorm heads and matching pistons on ebay from St.Paul HD for around $700. I haven't personally seen anyone with bolt on S&S heads make near that power. Good luck with whatever you choose and enjoy it!
Old 23rd March 2011
Thank you for the Buell tip. I have read a number of forum posts under the keyword search "heads" and I learned a lot. So needing different pistons is not too surprising to hear. Now I need to go study up on Buell heads and pistons. Thanks again...
Old 23rd March 2011
rodhotter rodhotter is offline
rodhotter has disabled reputation
give NRHS a forum sponsor a call, they know it all, do it all, sell it all, and will correctly answer questions
Old 23rd March 2011
We can do wonderful thngs with your stock 883 heads. Our stage 2 headwork using 883 heads has been known to pull 95 hp if the rest of yor engine is built to match. Best part is the cost for stage 2 light headwork using your 883 heads is only $800 and you can keep using the same pistons you have installed now.
Old 26th March 2011
Hmmm...now this is sounding good. Can you be a little more specific about "if the rest of your engine is built to match". I admit this project was not well thought out. In fact it sort of dropped out of the sky. But I'd like to keep some of my current add-on's such as my RB exhaust and my Super E. But...I do have an open mind, just not an open wallet. Thanks for helping. You are giving me hope.
Old 26th March 2011
Desertfox's Avatar
Desertfox Desertfox is offline
Sportster/Buell Model: 2001 883 Custom
Desertfox has disabled reputation
Let's see. S&S heads 2.00 inch intake valve, 1.605 exhaust, Buell thunderstorm heads 1.810 intake, 1.575 exhaust. Pluss S&S lets you go to an over .600 cam if you want as well as a two inch intake manifold. Do the math. However porting your basic 883 heads can give you a significant performance leap as well. Actually probably more bang for the buck.
If you hate me, I've probably given you just cause. There, feel better?
Old 26th March 2011
Again...I'm just a newbie with a lot of research and no experience but from what I've read on this forum (which I consider an extremely valuable resource) and other places, the NRHS Stage 2 Light job on stock 883 heads looks like a very cost effective way to do what I want...which is to surprise a few big twins and some big block 4 wheelers. Just for fun. That solution is looking pretty good.
Old 29th March 2011
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Sportster/Buell Model: 1200 R
Originally Posted by bluesburke View Post
Again...I'm just a newbie with a lot of research and no experience but from what I've read on this forum (which I consider an extremely valuable resource) and other places, the NRHS Stage 2 Light job on stock 883 heads looks like a very cost effective way to do what I want... That solution is looking pretty good.
Now you're catching on!!! Let Dan @ NRHS take care of your power needs!
Stuff: YES
Old 3rd April 2011
iraqsucks iraqsucks is offline
Sportster/Buell Model: xl883n
iraqsucks is on a distinguished roadiraqsucks is on a distinguished roadiraqsucks is on a distinguished road
it will be a few weeks yet, but i will have a dyno sheet for you to look at. i went with the 1250 kit with 10.5:1 compression pistons, stage 2 light headwork on my 883 heads, .536 cams, nrhs hurricane intake, and the d&d bobcat. im using a power commander 5 for my tuning.
