Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Tires, Wheels, and Brakes
0 H4 LED Conversion - write up with photos
0 Help identifying brakes
Last Post: bobandy
Last Post: SCarty
0 weld on hardtail
0 Down on oil
0 CV Carb hesitation
0 Mounting seat
Last Post: guidowisozk
0 TC88A EX lower MAP settings
0 Magneto insulating block removal
0 magneto twin plug heads
0 Cosmo's ECM Relocation Mod
0 i want a narrow/standard mustang vintage
5 Wet Dream, Ever Have One?
Last Post: Joe_jeep
0 Round Air Cleaner Poll
Last Post: Joe_jeep
0 Clutch Q
Last Post: wrkdWS6
0 Chinese S&S carbs
Last Post: Hornsmith
Last Post: BWP 5p
0 Rear wheel alignment
Old 23rd August 2014
nitrous jim nitrous jim is offline
Sportster/Buell Model: s1
Sportster/Buell Year: 01
Sportster/Buell Model #2: nitrous s1
Other Motorcycle Model: 10 second nitrous shovel
Other Motorcycle Year: 1971
nitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of light
Default dual front brakes for cheap
I used a caliper and master cylinder from ebay. I think they are from a kowasoki. I made a bracket out of aluminum. got a second brake rotor from ebay. total cast, under $100. I have the right caliper also but cant see how running it would make any difference.
to say the brakes work better is an understatement.
Its hard to say if I notice the increased unsprung weight. I know its there.
I had to change a tire in a parking lot and lost a bolt. the wrong bolt was temporary.
[IMG]http://[/IMG]
because the front now had better brakes I figured the rear needed more as well. ooops. too much.
the piece of aluminum on the axel WAS going to be a license plate mount
