0 Does 20W60 reduce cam gear noise?
0 Hagerty Insurance
Last Post: Pigskinner
0 TC88A EX lower MAP settings
0 Poll: Saddlebag Supports
0 magneto twin plug heads
Last Post: marioserafica
0 Fun or money?
Last Post: bill smith
5 Wet Dream, Ever Have One?
0 Down on oil
Last Post: Billy1200
0 1968 xlch
0 blonde, brunette, red?
0 Hamburger drum brake clunk noise
Last Post: nickfracture
11 How much did you spend on accessories in the first month?
0 I'm here to introduce Gristle.
Last Post: apotheon
Last Post: Randy_rots
Last Post: apotheon
0 Wish I had a beach with a ocean
Last Post: Akdawg
10 big bore question
0 Transmission figment
0 Smoke and top end job
0 2012 Superlow 883 settingfront Sag,need spacer Diameter info.
Last Post: Old Rocker
win307 (66), JrzyDave (59), WeirdNJ (59), Pigskinner (46), jeepsoldier (44), Virgdog (34), bernardderek, John Titor (22)
1970, clutch, ironhead, transmission
Old 18th July 2016
Automodown Automodown is offline
Sportster/Buell Model: xlch 900
Sportster/Buell Year: 1970
Other Motorcycle Model: Dyna
Automodown is an unknown quantity at this point
Default 1970 Xlch Transmission Problem?
Hello new to the forum. I have a 1970 XLCH kickstart only..well the other day I put the bike on the stand to do pushrod adjustment. Clunked through the gears to 4th with the plugs out like a usually do, did the adjustments and when I put everything back and when I was ready to to start the bike I could not get it out of fourth gear. I rocked it back and fourth...nothing. Now I am wondering if I should rip into the tranny or could it be something else? The clutch and primary have all been rebuilt about 2 years ago and I have had 0 problems with anything on this bike besides some carb issues which I fixed. Any suggestions?
Thanks
Old 18th July 2016
8ball's Avatar
8ball 8ball is offline
Bike Builder
Sportster/Buell Year: 1973
Sportster/Buell Model #2: xlch stroker
8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of
does it have a speedometer?
"ya...i saw a guy do this once... " -DR DICK
Old 18th July 2016
Yes it does. It does not have a tach thou.
Old 18th July 2016
bsaman's Avatar
bsaman bsaman is offline
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1972
Other Motorcycle Model: BSA Spitfire
Other Motorcycle Year: 1968
bsaman is a name known to allbsaman is a name known to allbsaman is a name known to allbsaman is a name known to allbsaman is a name known to allbsaman is a name known to allbsaman is a name known to allbsaman is a name known to allbsaman is a name known to allbsaman is a name known to allbsaman is a name known to all
What feedback are you getting from the shift lever when attempting to downshift? Check to be sure the shifter isn't loose on the shaft and not actually turning the shaft enough to complete the downshift.
Old 18th July 2016
The shifter is responding normal whether kicked down or up, it returns back to its starting point. This is got me completely stumped seeing that it happened when the bike wasn't even running and I was shifting through the gears by manually spinning the back wheel.
Old 18th July 2016
Le_Jack's Avatar
Le_Jack Le_Jack is offline
Sportster/Buell Year: 1976
Sportster/Buell Model #2: XLS (Barn Find WIP)
Sportster/Buell Year #2: 1979
Other Motorcycle Model: XLH (basket case)
Other Motorcycle Year: 1976
Le_Jack is a jewel in the roughLe_Jack is a jewel in the roughLe_Jack is a jewel in the roughLe_Jack is a jewel in the roughLe_Jack is a jewel in the roughLe_Jack is a jewel in the roughLe_Jack is a jewel in the roughLe_Jack is a jewel in the roughLe_Jack is a jewel in the roughLe_Jack is a jewel in the roughLe_Jack is a jewel in the rough
Did you try to lift the back of the bike o a stand to be able to rotate the rear wheel in forward only motion while keeping the shifter down (instead of back and forth for a small fraction of the angular rotation) ? How does both (shifter and wheel) feel doing it this way ? Any noise from the tranny ?
Old 18th July 2016
Yes I have it up on a jack now. I have rotated the wheel both ways with the shifter down and nothing. I turned the wheel by hand and with the kicker trying to get it to grab and nothing. There isn't any noise from the transmission. I am tempted to try to start the bike with the wheel off the ground but I don't know if my knee would appreciate that.
Old 18th July 2016
sounds like the ball on the end of the shifter shaft came out of the pawl carrier.if you pull the shifter shaft outward,does it pull away from the case more than an 1/8''?
Old 19th July 2016
Nope I just checked. There's a little play side to side but no where near 1/8 inch. I am beginning to think I might have to pull the tranny.
Old 19th July 2016
well cross that one off the list.shift lever would be dangling,if that's the case. tough to figure,because the bike never left,the lift.
