0 Struggling with year??
Last Post: Sugarsinner
0 How packed is your garage?
Last Post: unleashed
0 The Revolution's Rowdy Ancestor?
0 Dyno Run, V&H straight shots vs. Screamin' Eagles
0 Generator removal
0 '81 Gasket/Rebuild Questions
Last Post: Calcustom
0 oil line routing 79 ironhead
Last Post: bobandy
0 Forum member mug shots
0 THE Hockey Thread
0 4 Speed Stator Replace
Last Post: connorneil13
0 Polished rotor/brake pad compatability
Last Post: Firehawk
Last Post: Firehawk
0 Dynatek Ignition questions
0 compression low?
Last Post: 93trident
0 Hello from the uk I just got my first Harley!
5 1969 XLCH exhaust question
Last Post: Coz
0 I'm back...
Last Post: screndname
0 Random video thread.
5 RSD LED Indicator
Last Post: mk87ita
DAKSY (68), dwagar (68), DaveDuff (59), chaserband (57), bigcraig74 (46)
top end rebuild
Old 28th August 2016
Sportster/Buell Year: 1971
Sportster/Buell Model #2: xlh
Other Motorcycle Year: 2011
Originally Posted by Chuckthebeatertruck View Post
Did you have two piece or one piece cast oil rings?
On my '74, the oil ring itself was the original one piece cast ring, with the spring in behind..... which is why I referred to it as a 2 piece. Maybe I'm referring to it incorrectly.
Hadn't thought of the heat gun approach. Sounds like a quicker method to the same end. Thx for that idea.
Well then that is why the piston looked so good,
It was well oiled! :^P
cfijdman cfijdman is offline
Sportster/Buell Model #2: 883 Street Tracker
Other Motorcycle Model: Harley-Davidson Fat Bob
Other Motorcycle Year: 2009
cfijdman is an unknown quantity at this point
Man, I love the great feedback I'm getting. Keep it coming. I have a good heat gun will definitely try that approach first. You may notice I am going pretty slow on this teardown. l haven't had a lot of time to work on it due to other projects and commitments plus we have only had a few days recently that have no been unbearably hot and my garage is not air conditioned. I have also uncovered a leak that may require splitting the crankcase halves. I'll start a new thread on that one.
Old 29th August 2016
Chuckthebeatertruck's Avatar
Sportster/Buell Model: Xlh
Sportster/Buell Year: 1959
Sportster/Buell Year #2: 1969
Other Motorcycle Year: 1969
Exactly!
