Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Styles > Dirt, Off-Road, and Adventure
0 can you tell me why?
0 Coil OK but no Spark??
Last Post: vaquerodiablo
0 S&S MGAL carb
Last Post: fafcpa
Last Post: Eddieblz
0 Power cones
Last Post: JonesL
0 Arlen Ness Fairing
Last Post: hondo
0 Wheel fitment
5 Tire Pressure?
Last Post: Joe_jeep
6 English newbie
0 Fitting mini apes
Last Post: ivanford
0 .551 Cams in an EFI 1200
0 Forum member mug shots
0 Convert to wide glide front end
Last Post: motorfish
Last Post: Joe_jeep
0 ultima electronic ignition
0 will these fit my 2006 xl 1200c
Last Post: mwXL 2006
0 Noisy
0 93 Sporty Key replacement
0 Wheels
Last Post: NoRemorse
0 Wont shift from 1st to 2nd
Old 26th June 2017
fmacdonald's Avatar
fmacdonald fmacdonald is offline
Sportster/Buell Model: XL883L (now 1250)
fmacdonald has a brilliant futurefmacdonald has a brilliant futurefmacdonald has a brilliant futurefmacdonald has a brilliant futurefmacdonald has a brilliant futurefmacdonald has a brilliant futurefmacdonald has a brilliant futurefmacdonald has a brilliant futurefmacdonald has a brilliant futurefmacdonald has a brilliant futurefmacdonald has a brilliant future
Thanks, The Crusher not sure it is my cup of tea
2009 XL883L 1250 Hammer kit . SE Stage 1 with K&N 3'' Filter, Energy one extra plate clutch kit
Old 26th June 2017
The Crusher's Avatar
The Crusher The Crusher is offline
The Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond repute
Brother, that was nobodies cup of tea, that's why nobodies making it now, I just wanted to post that because of it's fuglyness.
It was a cheap looking copy of a rear end style that nobody liked when it was put out. I think it was only available on the 70-71 Sportster and 71-72 FX.
You can't keep a good man down......... unless you tie weights to his ankles.
Old 26th June 2017
fmacdonald's Avatar
You had me worried for a bit as I thought you liked it
Old 26th June 2017
Tom's Avatar
Tom Tom is offline
Sportster/Buell Model: 883R
Other Motorcycle Model: '84 FXE Super Glide
Tom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond repute
There sure is a bunch of good looking small tank Sportsters in that Instagram pic. The one with the long uncut frame rails is probably the best you could do without cutting them.
Old 26th June 2017
Well, thanks for replying so politely then.
That long rail sporty back end in the picture has some potential, it's just done horribly. If you filled those silly V's and put a tail light in that hole, then cut the front down closer to straight to define the rear of the seat and fix that snap looking stuff that wouldn't look bad.
Old 9th December 2017
cjoven cjoven is offline
cjoven is an unknown quantity at this point
You can hide the struts like on the rsd bike
45Brit 45Brit is offline
Sportster/Buell Model #2: 1978 XLCH project
Other Motorcycle Year: 1975
45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute
Since I’ve lost the earlier picture, here’s my early 90s 883R set up for Sport Twins Racing using Harley original components
The original, short strut frame extends just to above the rear spindle, and supports the number plates, as the RSD bike does.
There is also the fact that, at 61” wheelbase, the Sportster is about 4” too long for an “authentic” flat track look.
Old 10th December 2017
Big Al's Avatar
Big Al Big Al is offline
Sportster/Buell Year: 1989
Other Motorcycle Model: Harley FLH1200
Other Motorcycle Year: 1974
Big Al has a brilliant futureBig Al has a brilliant futureBig Al has a brilliant futureBig Al has a brilliant futureBig Al has a brilliant futureBig Al has a brilliant futureBig Al has a brilliant futureBig Al has a brilliant futureBig Al has a brilliant futureBig Al has a brilliant futureBig Al has a brilliant future
You know you're going to have to cut those support frame rails off for a good flat track look, so here's the Storz instructions on where to cut.
The instructions are for their seat, but worked fine for a faithful XR750 seat base copy I used for my wife's 1998 XLH1200 street tracker build. The seat was built by an English company https://www.triumphparts.gbr.cc/index.php/4/188770/ who used an original XR750 seat as a mould.
Old 8th February 2018
Tof851 Tof851 is offline
Tof851 is an unknown quantity at this point
You can install the Storz seat without cutting the frame, if you stay with the OEM turn signals, they will mostly mask the frame rails.
That's pretty slick.
