0 Chinese S&S carbs
0 Magneto insulating block removal
0 Down on oil
0 magneto twin plug heads
Last Post: Hornsmith
Last Post: BWP 5p
Last Post: ZCarFan
0 Clutch Q
0 Round Air Cleaner Poll
0 Rear wheel alignment
0 fork oil
10 big bore question
Last Post: H.E.L.M
0 Hamburger drum brake clunk noise
0 Pre-ride inspection importance.
0 Does 20W60 reduce cam gear noise?
Last Post: XL Dane
0 Hurriicane
0 TC88A EX lower MAP settings
0 Fun or money?
5 Wet Dream, Ever Have One?
0 Poll: Saddlebag Supports
0 Carb not squirting fuel
bad, cone, hot, ignition, timing
Old 3rd July 2018
groovemeisterus's Avatar
groovemeisterus groovemeisterus is offline
Sportster/Buell Model: XL883-1200 Branch Build
groovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of light
Not sure why youtube vid not showing up. I've embedded before, but maybe something has changed.
883 XL Y2K - BLACK,Ported Manifold,HSR 42mm Carb,Branch #5 Ported 883 Heads,Bob Woods W8S 0.590" Cams, SE -0.050" Perfect Fit Pushrods,SE 1200 Ignition Module ,Vance & Hines Straight Shot Exhaust,07 SE Air Cleaner,SE 40,000V Red Perf Coil,883 Jugs Precision Bored for Branch 30º Domed Pistons,& One Big Smile ;o), ~83TQ, ~83HP for now.
Old 3rd July 2018
https://youtu.be/qWSpuCsHGLo
Old 3rd July 2018
Glad you got it resolved... Bad VOES is unusual but...
Originally Posted by groovemeisterus View Post
Sorry took so long, had to order a VOES with 6 in Hg from Amazon since no Harley shop had them in stock. Go figure.
The stock VOES can be adjusted for your preferred switch point - see the Sportsterpedia...
2 Relax
Old 8th July 2018
2 Relax
Thanks. Yeah i've read the adjustable VOES sticky before. And used my oil light as an indicator from the past. First things first if need to adjust. When I start noticing same symptoms as before when idle or stopped when engine is hot, then will look into adjusting VOES.
Sturgis is coming up, and don't want any mis haps before hand.
