0 How packed is your garage?
0 Struggling with year??
Last Post: Sugarsinner
Last Post: unleashed
0 The Revolution's Rowdy Ancestor?
0 Dyno Run, V&H straight shots vs. Screamin' Eagles
0 Generator removal
0 '81 Gasket/Rebuild Questions
Last Post: Calcustom
0 oil line routing 79 ironhead
Last Post: bobandy
0 Forum member mug shots
0 THE Hockey Thread
0 4 Speed Stator Replace
Last Post: connorneil13
0 Polished rotor/brake pad compatability
Last Post: Firehawk
Last Post: Firehawk
0 Dynatek Ignition questions
0 compression low?
Last Post: 93trident
0 Hello from the uk I just got my first Harley!
5 1969 XLCH exhaust question
Last Post: Coz
0 I'm back...
Last Post: screndname
0 Random video thread.
DAKSY (68), dwagar (68), DaveDuff (59), chaserband (57), bigcraig74 (46)
carb, help please!!!, ironhead, opinions
Old 22nd February 2019
JSH JSH is offline
Sportster/Buell Year: 1979
JSH is an unknown quantity at this point
Default 1979 XLH Carb
What is the best new replacement carb for an old Ironhead nowadays? Opinions?
And is my old worn-out Keihn a 38mm or a 40mm?
Old 23rd February 2019
Skwerly's Avatar
Skwerly Skwerly is offline
Sportster/Buell Model: Unsure
Sportster/Buell Year: 1982
Skwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud of
34mm if I remember correctly. That's the year they went down from 38mm.
They are good carbs, I might rejet and rebuild. Save a lot of bucks, anyhow.
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
I had a screamin eagle racing carb put on my '73xlh on recomendation from a local Indy who was also pres of an MC at the time. Really knew the older bikes. He set it up and I have to say the thing just screamed. Perfect color on the plugs thru out too.
Yakcm2's Avatar
Yakcm2 Yakcm2 is offline
Sportster/Buell Model: XLS 1000 Roadster
Yakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond repute
If you just wanna make her into a rider again just rebuild the one ya got,
I rebuilt the Keihin butterfly on my 82 xls and it runs great, besides burnin alittle oil but that’s my issue.
Just make sure there’s not a lot of slop/play in the throttle shaft (source of vacuum leak) and she should be a good core for a rebuild, kits are cheap, save yourself alittle $.
Kevin
and that's my 2cents worth...
iNSaNeSHaNe's Avatar
Sportster/Buell Year: 1985
When the throttle shaft on my old butterfly got to loose to hold a steady idle i shit canned it and put on a CV.
It's much better all around, starting, riding, tuning, mileage, and parts are everywhere for them as well as upgrades.
Skwerly's Avatar
nice to know that's possible, i wasn't sure tbh.
the vm38 round slide mikuni is a popular replacement, simple but effective!
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
All above are good suggestions. As far as spare on the shelf carbs go. My fav is s&s super b.
KISS is pretty hard to beat.
Stock sucks.
Traveled to
Old 26th February 2019
wrkdWS6's Avatar
wrkdWS6 wrkdWS6 is offline
Sportster/Buell Model #2: XLH1000
Sportster/Buell Year #2: 1979
wrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond repute
I’ve got a S&S Super E on my ‘79. I dig it because it looks cool and it’s so simple and easy to work on and tune. A lot of Ironhead guys seem happy upgrading to the CV 40 carbs which is more cost effective than the S&S. I’ve had both on different bikes. Both will do the job.
'06 1200C - 1275, chain & '79 XLH - rigid, kicker, fancy paint, hopped up, 200 rear
