11th October 2018
Posts: 3,691 Sportster/Buell Model: Xl1250S Sportster/Buell Year: 98 Other Motorcycle Model: Kawasaki Vulcan 500 Other Motorcycle Year: 95
Originally Posted by 1hd4cjm1x4k
just change your oil often, and keep your levels correct.
+1
11th October 2018
Posts: 829 Sportster/Buell Model: Sportster Superlow 1250 Sportster/Buell Year: 2014
API used to require that all oils be able to mix with others. I don't know why they wouldn't now.
Tuned by Power Vision
Supertrapp Supermegs exhaust
1200 gearing, super brace
11th October 2018
And Amsoil is a small blending company. They have no refineries to make their own oil. Who do they buy their PAO from?. They get 90% from Exxon Mobile the largest producer of PAO in the world. They get most of their group 111 oil from Shell and Petro Chemical. Their add packs come from Lubrizol. Amsoil salesmen hate this. and some outright deny it but when you have been on bitog for a long time you find out stuff.
11th October 2018
My understanding is that true PAOs won't mix well with petro.
All other (synths, ahem) will since the base oil is petro.
People that live in extreme cold areas will probably be paying attention to the pour point temps of an oil.
In extreme heat, the flash point would probably be important.
But, the average flash point on the motorcycle oils I cataloged were in the 400Fs which is the low end of the boiling point.
The higher the flash point, the higher the viscosity also.
You can toss some numbers around on an online calculator also.
I just tried this one. You have to already know the 40C and 100C figures.
https://wiki.anton-paar.com/en/astm-...%5D=Calculator
I don't know of the accuracy though.
Ran the numbers on Motul 7100 synth 20W-50:
cSt at 40C = 126.5
cSt at 100C = 18
cSt at 149C (300F) = 7.1
11th October 2018
The fact that they are middlemen does rub some the wrong way.
That's still no reason to not use it.
There is nothing wrong with their product.
It's just not the 'be all end all' they would have you believe.
I have swapped brands three times since I upgraded.
I'm also using motorcycle oil in my 85 C-10.
Don't have a favorite but rather what I want to use.
I haven't used Amsoil yet and probably won't, but it's just I don't want to.
11th October 2018
Posts: 1,538 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2013
As far as API ratings, the only ones Harley lists to use are the diesel rated oils, CH-4, CI-4 and CJ-4. No recommendation for any S (spark) rating like SL, SM or SN. I haven't looked at enough different "MotorCycle" oils to know if any of them are diesel rated.
If necessary and H-D 360 is not available, add oil certified for diesel engines. Acceptable designations include: CH-4, CI-4 and CJ-4. The preferred viscosities, in descending order are: 20W50, 15W40 and 10W40.
11th October 2018
Posts: 177 Sportster/Buell Model: Custom 1200 Sportster/Buell Year: 2018
Some of the Diesel Oils have a MA rating. I forget which ones.
As far as our Lord concerning Diesel Oil, It also states to change to 100% Harley Davidson Oil. As per 2015 Street 750 Manual, As soon as possible.
One thing I do like about the Japanese bikes, They give you the API Specs. As well as the MA Rating requirements. HD, Good luck.
Tucsonmax1 2018 Sportster 1200 Custom, 2016 Hyundai Tucson SE AWD
11th October 2018
Posts: 8,802 Sportster/Buell Model: 1200s Sportster/Buell Year: 2001 Sportster/Buell Model #2: xlch Sportster/Buell Year #2: 1974
once again mr. hippy
wisdom beyond your years!
there is an old saying, oil never wears out, only the additives and it gets dirty.
on ocean going ships and now even in the oil environment, oil is changed on a sample, not time or hours. there can be thousands of hours run on the oil, the trick, keeping it clean (centrifuge) and keeping the additive package up (oil make up system).
the early honda's ran centrifuges but alas, people were not too smart and never serviced them so honda went to throw a way units.
11th October 2018
I think I remember a few spark oils also rated for diesel but It has been awhile since I looked into it.
The only reason the MA rating is important is if you are intending on using the oil in the primary also. So, that is also a consideration. Goes back to crossing the line I mentioned.
11th October 2018
I haven't found the diesel connection.
Doesn't diesel have more detergents for ash removal?
So what extent of detergents is too harsh for a (spark) engine?
